Bass is conventionally divided into three octaves. The lower range is 20-40 Hz. The middle range is 40-80 Hz. And the upper range is 80-160 Hz.
Does all of this account for 30% of our impressions of sound or not?
The 30% statistic came from Sean Olive's research.
Olive, S.E. (
2004a). “A multiple regression model for predicting loudspeaker preference using objective measurements: part 1 – listening test results”, 116th Convention, Audio Eng. Soc., Preprint 6113.
Olive, S.E. (
2004b). “A multiple regression model for predicting loudspeaker preference using objective measurements: part 2 – development of the model”, 117th Convention, Audio Eng. Soc., Preprint 6190.
Or you can read summaries of it in my books.
The bass correlation was first noted in Part 2 of my 1986 paper where the -10 dB bass extension had a -0.5 correlation with sound quality ratings - all other factors varying! This means that bass extension, by itself is an important audible factor. -10 dB correlated better than -5 dB because of room gain.
Toole, F. E. (
1986). “Loudspeaker measurements and their relationship to listener preferences”, J. Audio Eng. Soc.,
34, pt.1, pp. 227-235, pt. 2, pp. 323-348.
What Sean Olive found in his first experiment using bookshelf loudspeakers with similar, but not identical, bass extension, was that bass accounted for 25% of the overall factor weighting, of which 6.27% was bass extension, and 18.64% was bass quality (frequency response). In his second experiment which used 70 loudspeakers of all sizes the bass extension alone accounted for 30.5% of the overall factor weighting. The variations in bass extension were noted and appreciated. Smoothness very likely was a factor, but in these comparisons was less noticed.
The same phenomenon was noticed in an elaborate comparison of rooms and loudspeakers:
Schuck, P., Olive, S., Toole, F., Sally, S., Bonneville, M., Momtahan, K. and Verrault, E. (1993). “Perception of Perceived Sound in Rooms: Some Results of the Athena
Project”, 12th International Conference, Audio Eng. Soc., Paper 12-006. and
Olive, S.E., Schuck, P.L., Sally, S.L. and Bonneville, M. (1995). “The Variability of Loudspeaker Sound Quality Among Four Domestic Sized Rooms”, 99th Convention, Audio Eng. Soc., Preprint 4092.
In these experiments, when binaural comparisons of loudspeaker and rooms combined were done (i.e. listeners could not perceptually separate the loudspeaker from the room), differences between the loudspeakers were not significant and the room dominated. The most perferred loudspeaker/room
combinations were those with most bass, even when the bass was obviously boomy. Listeners were less discriminating in their assessments of the loudspeakers when bass was a significant perceptual variable.
People like bass, even bad bass is preferred to insufficient bass.
So the answer to your question is that the lower the cutoff frequency the better, and above that smoothness matters. Small room resonances are the problem in the real world. and the lower the cutoff frequency the more of them are energized. OK?
