ROOSKIE
There is no replacement for displacement. You want convincing bass and midbass get big woofers or very high xmax drivers or both.The compression itself looks rather harmless with this floorstander, which I mentioned in reply to the comment that rather very compact bookshelf designs are affected. They are even more so, naturally. Have stumbled across several very compact active vented speakers with pretty astonishing specs in terms of max SPL and lower cutoff frequency, which did not really sound convincing to me in the lower bass region.
Any small speakers with astonishing specs for high SPL and low bass are lying about things or you need to be filling a very small room like a closet.
Hoffman's Iron Law -
"Hoffman's Iron Law, in the context of speaker design, states that you can only achieve two out of three desirable characteristics simultaneously: low-frequency extension, small enclosure size, and high efficiency/output (loudness). You can't have all three; you must choose two, and the third will be compromised. " ai
That is exactly the problem. If port tuning freq at modest SPL is not hitting a mode, it might sound fine, but with certain sounds like kickdrums at higher levels it excites a mode for a moment.
I don't think you understand what I was trying to say. Oh well. Limitations of no telepathy allowed here.
The very slight shifting of the port tuning is only slightly changing output and at only very high levels.(@least in terms of the amount of change in the f35) There are much much bigger fish to fry in a listening space.
By the way the port/box/system tuning is changing with SPL, heat levels in the voice coil, ambient temperature and pressure, humidity levels and increased resistance in the crossover and voice coil when high power is sent to the system. If the port is close to a boundary it changes the
tuning. It changes by a couple or even a few hrz all the time for many reasons in almost all speakers even if not demonstrated in Erins test.
Then you go into a room where everything is affecting playback.
Heck even opening windows or doors to the room can change in room response measurements.
