Certainly true. But even if we accept that millions of recordings have been mixed and mastered on different systems, I would say there are a lot of similarities between studio control rooms, and the variations between most of them is much smaller than found between typical hi-fi setups at home. So if precise standardization cannot be achieved, we can still do some things to stay within the usual tolerance band of deviations found in studios. Listening in stereo and keeping and equilateral stereo triangle is the single most standardized aspect, while supressing disturbing early reflections achieving stable center phantom localization being the second most common. So why not follow at least these two?
Yes I have made similar arguments for that approach before. Even if you can’t re-create the listening scenario of all the mixing rooms you can in principal at least move closer or further away from that goal. For instance if you use a single loudspeaker for playback at home that would clearly be a move away from what they heard in the studio for stereo mixes. Placing your sound system in your tiled bathroom is also likely to be a move in the wrong direction, etc.
But of course, for all the reasons Toole has pointed out neutral playback at home does not avoid the circle of confusion. So one picks one’s compromises.
But as I argue, there are various legitimate roads to take based on any individuals taste or goals.
It can also make sense to take the stance many on ASR have voiced:
at least as it stands, trying to re-create what they heard in all the different mixing theatres is a fools errand. That’s a total out of reach version of accuracy. Therefore I’m simply trying to be accurate to the recorded signal itself - my motivation is to reproduce it with as little distortion as possible.
You can end up with the same type of accurate and neutral system, but for different reasons.
Or you can be somebody who just simply doesn’t have either of those goals, but is simply trying to please himself. Many audiophiles, myself included, like to “ play” with sound. I’ve owned plenty of different loudspeakers, all of which sounded different - everything from Quads to MBL omnis, to egg shaped speakers to various takes on traditional box speakers. That they all sounded different wasn’t for me a bug it was a feature. I wanted to hear something different from different loudspeakers. That was the fun of it. And I still play with set up and acoustics in my room simply because I enjoy the different effects.
I don’t worry about things like “ the artist’s intent” mostly because I think any intent largely translates through a wide variety of sound systems.
And while I am not ultimately looking for the most coloured speaker I can find (I don’t want to feel anything is obviously missing in the frequency response and I do want to hear the character of different recordings) I’m also fine playing with colorations like vinyl playback, and my tube amplifiers.
Yes. But how do you define which of your favorite tracks gives you the most of enjoyment from sonic point of view?
I decide this based on how the majority of my music sounds on my system not just a few tracks.
If your system deviates from the average studio tolerance band, one recording might sound fabulous, the next one annoyingly kinked.
But the same could be said for a perfectly neutral system. Due to the variable quality of recordings you’re going to get variable sound quality with playback on a neutral system as well. So the neutral system doesn’t in principle solve that problem. There’s a circle of confusion again.
Since your point there has to do with what somebody finds pleasant or not, if somebody finds a coloration they happen to like across a broad spectrum of their music (and it doesn’t have to be a gross colouration), then that can be just as satisfying - perhaps even more satisfying for them - then having chosen a perfectly neutral system.
To leave the circle of confusion, I plea for taking the percentage of recordings which ´just sound right´ and give enjoyment if they are within the genre limits of the listener´s taste, as measure how well the average sound reproduction is met.
I understand the argument you are making there - the more recordings that sound good on a system the more likely your system is getting closer to what they heard in the mixing studio. That doesn’t escape the circle of confusion really but still there might be something to that.
Be that as it may, as has been pointed out already, it seems audiophiles have found satisfaction with quite a variety of speaker, designs, and performance (and we can adapt to colorations). Over the years I’ve seen the occasional person moving on from a high quality Revel speaker to a more coloured speaker because they felt not enough of the music they listen to sounded pleasing on the Revel speaker, and they found more happiness with another speaker.
If I were making recommendations for a newbie, I would first be recommending well design loudspeakers like Revel or other affordable well measuring speakers. But somebody still may end up cutting their own path.
On the other hand, something between 80-90% of degree of satisfaction is achievable.
For me, I find having taken the “ set up a system that I find pleasing” approach, and even introducing a little bit of colouration, has yielded without exaggeration something more like 99% satisfaction rate with what I’m hearing. And that is with a collection of music of wildly divergent production quality. I’m perfectly happy with the variation between recordings as I find that interesting in of itself, and then I’ve introduced just the type of colouration that I find pleasing across virtually all recordings.
The other method of leaving the circle of confusion is visiting live concerts without sound reinforcement. From my personal point, the single most reliable way of judging if a system in a room ´sounds right´ is to visit a concert which will be subject to a broadcast or album issue later on. Knowing both, preferably with little delay between both listening sessions, gives you an astonishingly good understanding of how things should sound and what the mixing engineer was meaning. I personally prefer to hear what the broadcast mixing engineer is doing during general rehearsal, before I visit a concert, but I understand that is not doable for everyone.
That’s fun stuff! And I’ve been in bands where we’ve recorded in the studio, as well as doing my own recordings for live versus reproduced tests. I think this type of experience can be interesting.
But I certainly wouldn’t see how it would solve the circle of confusion which extends far beyond the limited experience one can have of the type you’re describing.
Cheers
