I mean if there's any posts from which can learn some electronic design?You're wasting your time, most audiophiles have no clue.
Not that hard to search amplifier classes for definitions and such....what are you concerned about?I mean if there's any posts from which can learn some electronic design?![]()
I lack a foundational knowledge of electronics. Due to the need for brevity, the definitions on search engines contain many terms I find difficult to understand. Moreover, videos explaining these terms might be created by biased audiophiles.;(Not that hard to search amplifier classes for definitions and such....what are you concerned about?
Amp classes are largely about design decisions.. A well designed amp is fine. Class A amps will generally be thermal/consumption issues but not generally any particular advantage. Look for well measuring amps no matter the design and you'll be fine.I lack a foundational knowledge of electronics. Due to the need for brevity, the definitions on search engines contain many terms I find difficult to understand. Moreover, videos explaining these terms might be created by biased audiophiles.;(
Actually, I often encounter the view that Class A amplifiers have the lowest distortion (because they are more "linear") and outperform Class B/AB types, despite their extremely low efficiency.Amp classes are largely about design decisions.. A well designed amp is fine. Class A amps will generally be thermal/consumption issues but not generally any particular advantage. Look for well measuring amps no matter the design and you'll be fine.
Why not? This site is about objective performance and Amir has comprehensive measurements of many amplifiers. If an amplifier has good measured performance, sufficient power for your application, the build quality and features that you want, then it is good enough. No need to worry about what other people say.Actually, I often encounter the view that Class A amplifiers have the lowest distortion (because they are more "linear") and outperform Class B/AB types, despite their extremely low efficiency.
Moreover, low-cost Class D amplifiers usually underperform low-cost Class A ones due to design complexity.
I don’t quite believe it, but I can’t refute it either.:(
all BSActually, I often encounter the view that Class A amplifiers have the lowest distortion (because they are more "linear") and outperform Class B/AB types, despite their extremely low efficiency.
Thanks for adviceWhy not? This site is about objective performance and Amir has comprehensive measurements of many amplifiers. If an amplifier has good measured performance, sufficient power for your application, the build quality and features that you want, then it is good enough. No need to worry about what other people say.
Sorry but I can't have access to Wikipedia due to some restrictions and lawsHere is a decent explanation:
Power amplifier classes - Wikipedia
en.wikipedia.org
Note that classes C, E and F are used only for radio/TV signals (more generally termed as RF).
It's a bit of a rabbit hole if you don't know any electronics, but everyone starts somewhere.
In simple words:
Class A gets very hot and needs to be large in order to dissipate heat.
Class AB needs to get bigger and heavier when they have to supply a lot of power. Again has to do with heat dissipation.
Switching amps can be very small, lightweight as they don't get very warm when they have to deliver power.
In general cheaper and lower power designs may not perform well (but may still sound good/decent) simply because of financial choices being made.
The time that class AB designs could sound bad or worse than class A is a long, long, long time ago. The myth however still goes around.
While cheap switching amps may work just fine they simply aren't as good in a number of aspects than more expensive switching and class AB amps.
Simply a cost decision made by the manufacturer.
Don't buy cheap crap even when people rave about it.
Don't buy overpriced stuff either which is supposed to 'sound better'.
Transducers and recordings all have a different 'sound'.
I have owned 2 class a power amps.
Have a suspicion that the different/better sound is more due to the heavy duty power supply needed rather than the class a bias itself.
As competent class ab amps often have a couple of watts of class a bias and that is all I, and I suspect most average audio enthusiasts, use, a good ab amp is all I need.
Like other said:However, a popular view among audiophiles is that power cords can also make a difference
You’ll get that a lot here!all BS
