A 4-Year Retrospective: Why "Density" is the Only Way to Fix the Fostex Sibilance (T30 & PPR Data)
Hilton
Title: A 4-Year Retrospective: Why "Density" is the Only Way to Fix Fostex Sibilance (T30 & PPR Data)
Intro:
Hey everyone, it’s Hilton. Many of you might remember my original 2020 measurements on the Lawton-modded Fostex TH610 (links to my original StereoNET and ASR threads).
Lately, I’ve been listening mostly to my Flame Marbled Walnut (Type 1) cups, but I found myself enjoying them less—they felt "fuzzy" and sibilant compared to my memory of the others. To solve the mystery, I went back into my archives and pulled the original .mdat files to look at the data through a fresh lens.
To help analyze the archives, a deep-dive analysis was performed with the assistance of AI on Google Search, powered by the Gemini family of models. A visual inspection of all REW frequency response curves and T30 decay graphs was performed, correlating them with technical notes and the Janka hardness of each wood. The results match the original subjective findings—even the impressions recorded before the headphones were placed on a measurement rig. The ears were telling exactly what the T30 decay graphs now prove: density is the primary driver of acoustic refinement.
The Hilton-Lawton Performance Matrix
Note: Harman PPR scores are mathematical estimates based on single-trace REW Target Compliance.
Wood ChamberEstimated PPRWeight (Cup)Sub-Bass (10Hz)T30 @ 6.5kHzHilton’s Verdict
Sennheiser HD60091 / 100N/ARapid Roll-off100ms SpikeIndustry standard; rings at 6.5k.
Wild Chechen (T4)88 / 10095gFlat to 10Hz<25ms (Dead)The Perfect Hybrid. Cleaner than HD600.
Wild Ziricote (T5)82 / 100115gRapid Roll-off<25ms (Dead)Clinical/Analytical "HD600-ish" Fostex.
Marbled Walnut (T1)76 / 10069g+6dB Boost35ms PeakMusical, but the 6.5k shimmer fatigues.
Black Limba (T1)72 / 10065g+6dB Boost100ms SpikeSublime "party" bass; massive sibilance.
Stock Walnut69 / 10041g-8dB vs LawtonRinging/PeakFuzzy/Sibilant baseline control.
Left to right - Wild Ziricote > Wild Chechen > Black Limba > Flame Marble Walnut
HD600 T30
TH610 Stock T30
TH610 Chechen Chamber T30
TH610 Ziricote Chamber T30
TH610 Marble Walnut T30
TH610 Black Limba T30
Final Technical Summary & Findings:
  • The Sibilance Solution (Verified): The T30 graphs for the Wild Chechen (95g) and Wild Ziricote (115g) prove they are technically cleaner in the sibilance region than the Black Limba and even the HD600. A "bright" headphone has effectively been turned into a reference tool.
  • The 10Hz Flatline (Verified): The REW frequency sweeps (confirmed by the RHQ-Retest) settled the debate: the Type 4 Chechen is the only chamber that achieves a flat 10Hz extension, providing that "live gig" impact without the "fuzz."
  • The Ziricote Paradox: Extreme density (Type 5) creates a clinical, "HD600-ish" roll-off by killing the resonant "bloom," making it the analytical choice, while the Chechen remains the "perfect hybrid."
  • Target Compliance: The Wild Chechen emerged as the "Harman Champion" (~88/100), satisfying both the 10Hz sub-bass requirement and the damping needed for a high preference rating.
Measurement Rig:
Captured via miniDSP EARS (HEQ Calibration) + REW, using a light elastic clamp for a perfect seal.
Conclusion:
Every measurement reviewed—from the 10Hz extension to the 3kHz dip—matches the original subjective descriptions. The Wild Chechen provides that "sweet shimmer" without the bite, while the Ziricote is the tool for those who want clinical speed.
NOTE:
"To address skepticism regarding the massive 6dB sub-bass gain, I performed a full RHQ Retest using a light elastic clamp for a perfect seal. The results were 100% consistent: the Lawton chambers (specifically the Chechen) achieved a flat 10Hz extension that the stock 41g cups simply cannot match."
