$9 Headphone Review: Sony MDR-ZX110
Sure, any tip change could change frequency response, but a huge change in bore length and geometry like that will likely have an unpredictably larger effect than a normal 3rd party tip. If you can send your IEMs with these custom tips to get measured on industry standard gear you might be able to correct for this with EQ, but you might not, due to changes in bore geometry possibly introducing acoustic reflections and cancellations and so non-minimum phase behaviour that cannot be effectively EQed out. CIEM tuning is very difficult to get right due to these issues, so you can't expect an IEM to necessarily sound fine or even be easily correctable with EQ if you just slap it onto an ear mold.
I'm not talking about the extra weight of the ear mold, I'm talking about the weight distribution shifting to outside the ear canal entrance from the weight of the IEM (which is often not insignificant, sometimes made of metal) protruding out of the ear that I'd imagine would cause pressure points in the canal from the mold and so affect comfort, which is one of the major reasons to get custom-molded IEMs in the first place. I doubt they would just disappear into the ear and be almost unnoticeable like purpose-built CIEMs do. Of course, all these reservations could be confirmed or denied if you get some of these custom-fit eartips, try them out and report back ;)
I suspect the manufacturers of these tips know a lot more about what they're doing then you seem to give them credit for. I'll listen to them instead.
The outer ear may grow with age, but for most people (adults) there won't be significant changes in their ear canal, unless they go through a dramatic change in weight. I've had mine for over 6 years and they still fit just as perfectly as when I first got them (these are acrylic molds, silicone may wear down slightly over time).
It's actually entirely unremarkable for people's weight to change *greatly* over time. The word "dramatic" is a distraction. People often gain weight quite steadily as they approach and go into middle age. It isn't dramatic but is often significant. Also it's really, really easy :) Trust me, I know. I also know that I (now 53) need a different size of foam tips for IEMs than I did even 5 years ago.
The PEQ of the Toneboosters Morphit plugin works well.
Toneboosters provides 2 for-pay Eqs in UAPP, a PEQ, and Morphit. Morphit provides a selectable drop down menu with equalization profiles for tons of headphones (but not the ZX110), with a few different target responses: Harman AE/OE, Harman IE, "Studio", Diffuse field, free field etc.... So, you choose the headphone, then the target response. Playing around with Morphit on my Shure SRH840, Denon D2000 and Bose QC20, it sounds better to me than any of the profiles on the autoeq site. Having the option to change the target response (Harman, free field etc) makes a big difference in tailoring it to better match your preference.
The PEQ SW is the one that provides 6 PEQ filters and a few unique features, like the ability to choose the shape of the filter, For example, digital bell which I think is like what is spit out by REW's filter calculation, or analog bell emulating analog equalizers (no "cramping" like digital eq.)
I got in contact with Toneboosters about these and they confirmed that Morphit is higher than 32 bit. I measured their distortion and found none.
Both of these are amazing and my go to outside of Windows. I even use the PEQ for room correction running Tidal through UAPP on an android set top box into my home theatre system.
How do they compare to the DT 770 in your sig? I was thinking of getting those (not yours, but like from amazon ;)
The ZX110s are more comfortable. The DT770s aren't uncomfortable for their size. But, they just can't compete with something so light. Sound wise, when both are PEQed, the DT770s are better in every way. The main thing is bass performance. But, the bigger drivers and over ear design help things seem a bit out of your head more. The DT770s also have much better noise attenuation.
So ya, nothing you wouldn't expect, really.
@amirm Thanks for providing those earpad measurements! Is the pad depth the depth from the driver to where the earpad ends? I assume so, but just want to be sure.
Yes, it is from the top of the pad to the inside where the driver ends. In other words, it is the internal thickness of the pad.
there is a parametric eq you can buy as a add on for small change as part of offering in UAPP. verum1 is not included in morphit presets either, i got settings from oratory's list and tweaked 10 band parametric eq in uapp ( only 9 bands needed for verum1, left 10th band disabled) i am actually listening to it right now. this is a magic app and i thoroughly recommend to cell phone music listeners with add-ons. add a dac like tempotec sonata pro hd and you have a solid solution for very little money competing with big money products.
John, that reminds me of my position on vinyl, turntables, tonearms, and cartridges. If you want to just listen to music in SOTA High Fidelity sound, you're using a digital source. If your a more a gear head that wants to play with toys, your doing the vinyl thing. :p
Hey, I had one of them for years,.
As if every other third-party eartip - custom molded or not - isn't going to have an effect on frequency response? They do, and that's just the nature of the beast. But, guess what? We've EQ to compensate for it... :p
The comments about looks? It's in my ear, I don't care, and this isn't a fashion show.
Weight distribution? Now you're speculating about a gram or two of material at most. If I put a diamond stud in one of my earlobes, but not the other, I'm going to wind up with a sore neck at the end of the day? Really? ;)
You are the cynic. A good looking mask and matching headphones are fashion statements at Walmart, Target or Costco.
Hardly an exhaustive study, but I spent about a half hour running through whatever pop songs Youtube's sidebar fed me and I'd say I definitely have a preference for Maiky's EQ over Amirm's.
$40 complete headphone system:
Net10 LG Rebel TracFone: $30 DAP
Throw away sim and use on wifi. No activation required
https://www.amazon.com/dp/B07QHQ79XH/
MDR-ZX110 $10
Amazon Music HD. Boost bass a bit with it's simple 5 band equalizer.
'Amazingly good'.. better than my motu g6
Listening to Masaaki Suzuki Bach Organ Works. Actually very nice! :)
yes, and you can burn it.
Actual headphone burn-in I have only heard anectdotals.
There does not seem to be any proof of this.
Brain-in and pads compressing ... YES
MDR-ZX110 $10
Refurbished Rebel 4 TracFones are currently $9.99 if $30 is too much!
