TLDR:
PC as my source, Massdrop SDAC, no music playing, volume set to 100%, noise floor measurement, how do I get rid of this 8kHz spike?
Some history:
I bought my first external DAC, SMSL SU-8, this past summer and while it was a huge update over my existing equipment in terms of sound quality it also brought with it some audible noise during quite sections of music / no music playing. At the time I thought it was a ground loop problem so I bought a iFi iDefender3.0. It reduced the noise but not enough to my liking. So I returned the SU-8 and bought a "MASSDROP X GRACE DESIGN STANDARD DAC BALANCED". The noise was significantly better but after awhile I noticed the 8kHz noise.
How do I get rid of the 8kHz peak? What do I need?
A better power supply for the iFi and thus SDAC? I thought about this but the SU-8 had a nicer power circuit (directly AC powered with ground and a with torrid transformer) than the SDAC (just USB powered) and the noise was still there.
What about a better DAC? I've thought about the Topping D50s or even a SMSL M500 but I don't have a good feel if they will actually fix the problem. I notice the M500 doesn't have a grounded power cable. I wonder if that makes a difference?
Thoughts?
As a short aside:
Here is my noise floor without the iFi iDefender3.0 (note I'm not doing anything to minimize external noise, so there is non-trivial PC fan noise and cars driving by some in both this measurement and the above measurement). So you can see there is tons of noise coming from the PC that the iFi actually successfully filters out.
Some history:
Thoughts?
As a short aside:
