NotInYourHead
- Joined
- May 18, 2025
- Messages
- 125
- Likes
- 100
The Sure Wondom AA-AB41173 is essentially a multi-channel DAC with USB input. A Bravo SA9128 chip provides USB input, as well as 4 I2S outputs for the bottom board. A connector then routes the I2S signals to four PCM 5121s and provides eight output channels. You only need to provide 5V and data through a Type-C cable from your PC.
Now, the special thing here is: there's complete freedom to set up your system. You can use the I2S outputs, combined with Sure's TAS amplifiers, to create fully digital systems. On the other hand, there are 4 stereo analog outputs powered by quality PCM DACs. You're not tied to a particular amplifier, which is a problem I find with DIY DSP amplifier combos.
Even better, the icing on top of the cake is that it's only going for $55 (shipping and taxes not included). 8-channel DSP at this price point is INSANE. I think Sure Wondom made something wonderful that really scratches the itch for budget multichannel DSP.
The only 2 caveats I have are: is 5V from a USB port sufficient (and clean) to drive such a complicated circuit? And you're tied to a PC for DSP adjustments. Personally, I listen to music from a desktop setup, so no biggie, but what if you don't want PC clutter? Maybe a Raspberry Pi could be used for wireless streaming?
