WaynesterUK
- Joined
- Aug 20, 2020
- Messages
- 46
- Likes
- 12
Okay! a controversial topic!
can I ask why you guys say to put all crossovers on fronts centre and rear surrounds at 80hz?
After I’ve run Audyssey on my Denon AVR-X2200, it always sets my Fronts, rears and centre at 40hz...
I then always change them to 80hz as the recommendations, then I set my fronts to SMALL as it always sets them to LARGE
im just asking out of curiosity
seeing as I have big floorstanders, would you recommend putting fronts at 70hz? Then centre at 70hz and leave rears at 80hz?
An explanation for a thicko like me so I understand the 80 80 80 recommendation would help, I know it’s THX standard, but what if your watching music Blu Ray discs with DTS-HD sound or similar
here’s the specs on my speakers, if you do want me to change the 80 80 80 thingy?
BK XXLS400 FF SUBWOOFER
Specifications
System Type: Active System with Variable Freq bass filter and 50 Litre Sealed Enclosure
Frequency Response at -3dB:
In your front room -3dB lower than 20Hz !!!
Amplifier Input / Output Impedance: High Level 100K - Low Level 10K
Gain Control Range: 60dB
Drive Unit Impedance: 4 Ohm
BRONZE 50 REAR SURROUNDS
Frequency Response (-6 dB)
62 – 25,000 Hz (Free field)
40 – 30,000 Hz (In room)
Sensitivity (2.83v @ 1m)
85 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.4 ohms
Maximum SPL
107 dBA (pair)
Power Handling (RMS)
80 W
Recommended Amplifier Requirements
20 — 80 W
Bass Alignment
Bass reflex - HiVe II port system
Crossover Frequency
2,500 Hz
Drive Unit Complement
1 x 51/2" C-CAM bass/mid-range driver
1 x 25 mm C-CAM Gold Dome tweeter with UD Waveguide
BRONZE 500 FLOORSTANDERS
System Format
21/2-Way
41 – 25,000 Hz (Free field)
32 – 30,000 Hz (In room)
90 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.1 ohms
Maximum SPL
116 dBA (pair)
200 W
60 — 200 W
Bass Alignment
Bass reflex Dual HiVe II port system
Crossover Frequency
550 Hz
2,700 Hz
2 x 8" C-CAM midbass driver
BRONZE C150 CENTRE SPEAKER
System Format
2-Way
83 – 25,000 Hz (Free field)
66 – 30,000 Hz (In room)
88 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.3 ohms
Maximum SPL
109 dBA (each)
120 W
30 — 120 W
Bass Alignment
Sealed cabinet
Crossover Frequency
2,700 Hz
2 x 51/2" C-CAM mid-range driver
Specifications
85 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.4 ohms
Maximum SPL
107 dBA (pair)
80 W
20 — 80 W
Bass Alignment
Crossover Frequency
2,500 Hz
System Format
21/2-Way
90 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.1 ohms
Maximum SPL
116 dBA (pair)
200 W
60 — 200 W
Bass Alignment
Crossover Frequency
550 Hz
2,700 Hz
System Format
2-Way
88 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.3 ohms
Maximum SPL
109 dBA (each)
120 W
30 — 120 W
Bass Alignment
Sealed cabinet
Crossover Frequency
2,700 Hz
