Hello folks ! I'm seriously torn between Genelec and Neumann—both are excellent speakers.
Besides price, I'm considering two options:
1. Genelec 8030C + SVS SB1000(woofer, slightly cheaper than the genelec 7040B) with MiniDSP package for room correction.
2. Neumann KH 120 II + KH 750 DSP(woofer) with MA-1 for room correction.
For casual listening, which do you prefer? In particular, how is the sound quality? Is there anything I should consider?
My vote goes to Genelec 8030C, had both Neumann kh 120 ii and 8030C at home and subjective impression was similar to many comments at Thomann’s store: KH 120 ii is very unforgiving to sub pair mixes, very appreciated by DJs and editors to dig into errors whereas general consensus that in 8030C barely all sounds good.
This is not a typical comment for ASR, but you ask for opinions.
Neumann kh 120 ii for professional analysis, Genelec 8030C for casual listening: is a very “round” speaker with a lot of enjoyable listening experience, kh 120 ii is somehow “dry”. Maybe the DSP algorithm that correct phase, I don’t know but sounds a bit “unnatural”
Anyway this is very subjective, my advice is that you can buy both if you find a dealer with good return policy (Thomann is the best, 30 days trial period, money back program without any questions about the motives of return). Try them at home.
Looking at your 2 options you are in the same preference range than me, so want a flat and smooth active speaker: both are the best in 5 inch studio monitors valid to home listening.
Both have good FQ response, both are good for near and mid field (if you listen at moderate SPL), both have good directivity (except on the crossover region, as all 2 way monitors because vertical interference woofer-tweeter)…
Don’t believe so much you can go to the claim of high SPL of kh 120 ii: recommended distance is the same as 8030C.
MA-1 is not a game changer IMHO, I prefer using my own DSP and go analogue after, but for many people can be the main reason to choose kh 120 ii. In this case you can consider Genelec 8330A which is the equivalent of KH 120 ii but is older and is not as good as 8030C in its pure speaker measurements.
POST EDITED: I forgot to mention that if you use money back program from Thomann, be aware of posing KH 120 ii on the floor or any hard surfaces, use a towel or another tissue. The finishing get scratches so easy, mines had a reduction on refund because that, were completely scratched at the bottom after changing speakers back and forth.
