7Hz x Crinacle Zero:2 IEM Review
Rate this IEM:
    Votes: 7 1.4%
    Votes: 13 2.5%
    Votes: 68 13.3%
    Votes: 422 82.7%
I saw someone say that it isn't the earphones that require burn-in but it's the brain that adjusts to the EQ of the set. I think that's true and I can now more happily tolerate what I previously experienced as the louder highs of the Zero 2. I rarely use an EQ anymore as it's inconvenient. Only very occasionally do I find myself wanting to use EQ.
Finally, I took a complete tolerance break from caffeine of more than a month. Absolutely zero caffeine intake for this period (no tea, no coffee, no Coca Cola etc.). I found that when I made myself a strong coffee (I'd estimate around ~140mg) after this tolerance break that I was unequivocally high. My body temperature rose so much I had to take some top layers of clothes off! I had a peak of over 2 hours where I was listening to Astral Projection and was so high that I could probably have gone raving without the need for any other drugs! It felt like it should have been illegal for how high/stimulated I was :)
For those of you who used to or still do listen to music under the influence you'll understand this effect. I was amazed at how being high from coffee made music sound so much better. I'm otherwise sober for many years but after taking a coffee tolerance break I found I could enjoy music so much more intently.
...craving a bullet style / cable down IEM. I decided to take a chance on the Tanchjim Zero Ultima.
The stock tuning of the Ultima is horrible...
For me the comfort and convenience of the Ultima is now a massive improvement. I don't care about detachable cables as I never replaced the cable in my 7Hz Zero:2 and I treat IEMs in this price range as consumables anyway.
This process has repeated itself. After psycho-acoustic calibration ;) and a return to coffee drinking the Tanchjim Zero Ultima earphones now sound fantastic to me with their stock tuning. They disappear in my ears and are comfortable to use. I've ordered spares from Ali and this is the end of my interest in Chi-Fi IEMs. A high quality 9/10mm DD in bullet form is all I need. I'd recommend anyone to give them a try.
Generally, I agree. I really do not care for the around the ear form factor. I got the Zero 2s because of the review here, and they do sound fine. I'm just not real enthusiastic about having ti fiddle with them.
I also did some research on why many of the behind the ear designs seldom have well-marked left and right channels. The consensus is that the Chinese manufacturers feel that left and right markings blemishes the earphone authentically. It's an aesthetician choice. And they feel that the consumer can figure out which is right and left by the way they fit around the ear. That is true, but I feel that clear right and left markings are better. Generally, the Japanese manufacturers have clear right and left markings.
Also, when the Chinese companies makes straight in, drop-down earphones, for which there is a market in China, they label them right and left clearly. There is also a demand for old-stle earbuds like Sony pioneered. These too have clear right and left marking.
I thought the whole phenomenon m8ght be because one can read Chinese from left to right or right to left. You can read in either direction. But this is not the reason. The reason seems to be purely aesthetic. The companies pride themselves in the aesthetician appearance of their products.
Man what an iem. It's one of the products I've been most pleased by(and I've had a couple of iems up to 500 dollars).
Somehow had this idea that single dd just can't reproduce super high frequencies correctly and these prove this wrong for 20 dollars...
I get two distinct peaks though, and they are very consistent with Amir's gras measurement in magnitude. With a deeper fit these are 7.2 and 11 khz. I think these are resonance peaks as usual, they're just more pronounced than what I usually get(which also explains why they show up in dampened rigs as well) They tend to travel a lot depending on your canal length and insertion depth, some people (like resolve) hate these due to the first peak showing up at 5k, which is way more perceptually relevant and will actually ruin things unlike 8khz
I figured there are two things you need to do to make this iem incredible for yourself(it works for others too, but here it's more important than usual):
-Get these as deep as possible(which for me meant getting an aftermarket small and short wide bore tips)- like the pink ones they provide, but a lil smaller. Need a seal that won't make them travel in your ear as they slide out
-After step one, run a tone gen and look for two resonance peaks. One will be 5-8khz and the other 10-13. They differ in magnitude and width, but again, mine are very similar to Amir's measurements in width and magnitude. Don't do too narrow cuts, as they might travel a little depending on your insertion depth session to session, for me it's pretty stable as my baseline is as deep as they can get.
The magic is....after the resonance peaks, these just sound incredible. You arguably need nothing else(although I prefer less at 1-2.5khz matching 5128 df and maybe a little bass cut, though I might be alone on this one). Hella neutral, kind of a perfect iem for me. I had way harder of a time dialing in truthear nova for example, which in itself is great
i have peaks at
medium around 2700
big at 3300
and smaller to medium around 9000
no peaks from 10 to 13khz
and from 5 to 8 perhaps there were some smaller ones but nothing deserved of correction
i have peaks at
medium around 2700
big at 3300
I'd guess you get two at like 5 and then the 9. That would put you into big ear canal and/or shallow insertion group.
As for 3k weirdness, people can get different ear gain peak. I heard many people say their eargain peaks at 2.6khz, so this area is too quiet for them on "neutral" iems and then 3-3.5k is too loud. Maybe your eargain is at a usual place, but like skinny? :) idk
I recently got the Zero:2 out of curiosity. I will say that I knew beforehand that I'm not a fan of the Harman IEM target and that it sounds wrong to me - probably related to my inner ear geometry or something. After some EQ, it's in line with my preference target and performs as expected. The two resonance peaks exist for me, too.
The supplied set of tips (6 pairs) looks useful. However, the stock cable (without mic) is thin and feels very cheap. It transmits the audio just fine, so I guess it does the job. We will see how long it survives - maybe my impression is wrong. Handling it certainly does not inspire confidence. You could argue that they spent the BOM cost where it counts though, which would be the well meaning interpretation ;)
surely the cable is very thin, but you can consider two things: one: when you are on the move, it does not stress the connector or the IEMS. Two: It is absolutely not microphonic, so you get no disturbing noises generated by cable friction. I've tested a braided balanced cable but I've quick moved back to the original.
Yes, and also when you are not using them, a thin cable takes up *much* less space than a thicker one when putting them away in a pouch, pocket, etc.
Yes I've got both. The Chu 2 is more v shaped and sparkly. The Zero 2 is more neutral to me, but has excessive sub bass. The Zero 2 is very tip dependent for me. At the end of the day my Zero 2 is my go to when traveling or doing chores around the house.
The Zero 2 build is cheap plastic and the Chu 2 has an awesome all metal build. The Chu 2 is also more comfortable. I gave the Chu 2 to my wife. She loves them.
Out of sheer curiosity, has anyone here compared them to the Moondrop CHU II?
FYI there is now a Chu III, and the Zero 3 is supposed to release in the next month or two also. I know it's only $20, but may want to hold off for the new releases.
I might order these to compare them with the Truthear Gate. The bass boost and smoother treble sound great, other things equal.
I purchased the Zero 2 a while ago after reading Amir’s review. I’m not too keen about using IEMs (they always sound a bit confining to me personally and I don’t really like the sensation of something inside my ear) but when out in public, and being something easy to just stick in my pocket, they definitely have their purpose.
I haven’t used them for a while but last night I used them with the Apple dongle (a really good DAC overall), and they sounded very nice without any PEQ.
The cables on these current inexpensive IEMs are not the greatest but that’s easily solved with the many Linsoul cable options out there. And one can purchase any tips for them that they might prefer. Doing that bumps the cost but still sitting under 50 USD.
I’m not sure that ultra expensive IEMs have a purpose these days except for perhaps their build quality (many are very nicely constructed). At least in my world.
How are peoples long term usage of these and other cheap IEMs? How do you find the durability in particular?
I got my first pair of Zero 2 a few years ago but after a while one of the buds got really quiet and I couldn't fix them no matter what I did, so bought another pair which now got the same problem with one getting quite a lot quieter making the audio tilt to the left.
Interestingly I did save my old pair just in case this happened again, and now when I tried them on both buds worked perfectly again?!
Well not perfectly, they are a bit tilted to the right, but low enough that I can live with a small twist on the balance knob.
I do also have a pair of Truthear Gate that also started getting a bit unbalanced, but instead to the right. With these I even played some sines at different frequencies to see what was happening and to correct it, and it was mostly the upper frequencies (around 3kHz and above iirc) that was off. With some EQ on the right bud I could make most sines stay in the middle.
So how are other peoples experience with this? Is the music still perfectly centered or have it started drifting with time (and even drifted back)?
I’ve been using the Zero:2 for about a year in a home theater setup, and I haven’t had any problems.
When I found this, my big reference headphones (Sennheiser HD 600 and HD 800) were retired very quickly.
These outperform them in every way sound-wise, ergonomically - and at a fraction of the price. In my opinion, a top-of-the-line IEM like this is the perfect way to implement headphone listening.
Whether it’s game audio, TV shows, movies, or just regular music, here’s a player that’ll get the job done.
Thanks to ASR for this. Without Amir’s posts about this amazing subspecies in the world of headphones, I wouldn’t have discovered the performance & potential of IEMs.
Here's Zero:2 with its comrades, ready and waiting for their next mission.
Thought I had an issue with one of mine, twice. Both times it turned out it was the grill + filter. First time there was a bit dirt so went to clean it but noticed a huge crack in the grill. Removed both and sound was back to normal-ish so confident that it wasn't dying and I could just replace the grill + filter. Second time, the grill had somehow become detached from the adhesive and both were misaligned and causing an obstruction. Repeated same fix. All good since, touch wood!
