- Joined
- Jan 11, 2026
- Messages
- 400
- Likes
- 220
I've gotten good seal with flimsy/cheap stock eartips (of the original Zero), the point is that they nead to fit your ears and be inserted correctly. I would suggest the likely cause is that the stock tips aren't big enough (too small diameter, or not long enough).I guess you are using the useless flimsy stock eartips?, spend $10 of some decent silicone eartips and make sure you have a seal as these iem’s are in no way bass light
Foam tips are probably the easiest to get a good seal with (try Comply 500 ones, but they are expensive), as they expand once inside your ear, so they will fit more people's ears properly. Flange tips are also easy.
If you have other earphones that seal/fit well, you can measure the tip size and try and get ones eith a similar outside size.
Make sure anything you get fits the earphone though (either because the manufacturer says so, or they say they support earphones with the same nozzle diameter as the Zero 2, which you can measure with a ruler).
