7Hz x Crinacle Zero:2 IEM Review
Rate this IEM:
    Votes: 8 1.7%
    Votes: 13 2.7%
    Votes: 64 13.3%
    Votes: 397 82.4%
Has anyone measured/compared any of the following- KZ EDC Pro, KZ Saga Balanced, 7Hz Aero, 7Hz G1, Kefine Klean, Kiwi Ears Singolo, Tripowin Vivace to the 7Hz Zero 2? They have closely related frequency response measurements, but it's impossible to find any demos for them where I'm located (I've already tried Lendmeurears, Stereo Electronics, Zeppelin & Co, The Hangout by Crinacle, AV One, ConnectIt, Jaben and SAM Audio) and no one seems to have detailed measurements of them yet
If I may add, the Zero 2 made it easy to hear the difference between the audio quality of an Apple dongle, in comparison to a TempoTec Sonata BHD dongle. This difference was now obvious.
The issue with the Zero 2 are the limitations of dynamic drivers, hard to compare with planar magnetics. Unfair competition.
Yeah I also noticed it was really easy to differentiate source differences with good budget iems like the Zero 2 and Kefine Klean. The improvements of my Motu M2 over my Poco X3 NFC is immediately apparent, and the same applies to even microphone and iem comparisons on the Youtube channels Podcastage and Dan's Audio Reviews for example
Reactions: OK1
The budget IEMs are like temptations, one fears missing out. I am so glad I took the plunge and experienced the Zero 2(decent single dynamic driver), as well as the ARTTI T10 (planar magnetic). Then I wonder Kefine Klean - DLC - Diamond like Carbon, what does that sound like?
I assume you own the Kefine Klean, and if so, please how does this compare with the Zero 2?
I'm also a huge fan of Podcastage and Dan Worrall's channels (assumed from the name Dan)
Some clues (EDIT- Ninjad by Static)View attachment 403209
Hi I've recently discovered the world of iems and bought some 7hz crinacle Xero 2s.
I'm having issues with sealing them and have tried a few ear tips and but I'm getting a tinny sound. If I hold them in a bit they sound amazing but when I let go..... It returns to a very thin sound.
I'm wondering does anyone use galaxy buds 2????
As these fit my ears perfectly and if so what iems fit them as well as the galaxy buds?
Any help would be gratefully received!!
I'm so close to falling in love with cheap iems if I can just get a pair that fit 100%
This is a review, listening tests, EQ and detailed measurements of the 7Hz x Crinacle Zero:2 IEM. It was kindly donated to me by a member and costs US $24.99.
The cable is soft and longer than typical which I like. They take fair amount of effort to push it but then they make a reassuring soft click. The tips look cheap and are quite soft. You may need aftermarket ones. I tested and listened using the default red ones you see in the review picture.
Compared to 7Hz Zero IEM that I reviewed recently, these supposed to have a bit more bass and less treble. Let's measure to find out if that is the case.
7Hz x Crinacle Zero:2 IEM Measurements
Let's start with our standard measurement on GRAS 45CA measurement fixture. I was pleased that they fit instantly and generated the predicted results:
At high level, this is excellent compliance with our target leaving enough room for manufactures to tune and owners to decide based on their taste. Getting specific, ignoring sub-bass, we have a bit of lift between 100 and 300 Hz and some short fall from 4K to 8K. So overall I expect these to have a bit more bass and more closed in/less sparkle than the original Zero. Here is the relative response for EQ development:
While the differential is not great, developing precise filters may be bit challenging due to their shape. Then again you may not need to modify the response anyway.
The distortion measurements made my jaw drop:
As you see, even 114 dBSPL generates negligible distortion by transducer standards. It was so low that I decided to zoom way in. You see noise on the blue 94 dBSPL indicating corruption due to measurement noise. So in reality performance is better than that (SINAD of nearly 80 dB). This is one clean sounding IEM.
Absolute levels also show the same:
Group delay shows no news which is what we like to see (and is typical of IEMs):
Impedance is flat and low which is as expected:
Combined with average sensitivity, just about any source can drive it:
7Hz x Crinacle Zero:2 IEM Listening Tests and EQ
First impression was that familiar sound I hear from accurate transducers with two differences: the highs were a little recessed and at times I was hearing bass I didn't even know was there! I went after the former with EQ:
The measured shortfall in treble is 5+ dB. I started there and while that brought fantastic amount of detail and great improvement in spatial qualities, after some listening, I realized it is too bright. I pulled it down to 3 dB. Listening to bass heavy tracks I started to be bothered a bit about the extra upper bass. I dialed in a filter for that which solved that but them made the sound bright. I took down the treble EQ to what you see and reduced the amount I had taken down the Bass. These values are basically 40% of what measurements indicated. AB tests of EQ and no EQ showed preference for EQ.
Then I sat back and listened. That deep, impressive sub-bass is there and is now so clean. The highs are to die for. I have no immediate comparison but I kept getting surprised by the clarity up high in tracks that I have listened to hundreds of times for review. As much as I have had the pleasure of listening to some really great headphones and IEMs, I continue to be startled by moment to moment level of fidelity as I continue to listen to them. I think this IEM will likely make you not like your regular speaker system unless it is of highest caliber! The sound is just so good.
Also amazing is the level of instrument separation/spatial qualities. So, so satisfying. I can't say enough good things.
You have to shake your head when you see and read about the performance of this $25 IEM. It displays a level of performance with a bit EQ that is world class. Feed it some well recorded music and you are there: the pinnacle of high fidelity sound. I don't care if you don't want to use an IEM. Get one of these (or the original Zero) and get calibrated on what good sound is.
As to whether to get the zero or zero:2, I would say that with the above EQ, Zero:2 sounds more to my liking than the original 7Hz Zero. That one though sounds more correct without EQ. Your opinion may vary.
I am happy to recommend the 7Hz x Crinacle Zero:2 IEM.
Have you tried with all included tip sizes? After much much trial and error I have found that my ears need bigger tips that most IEM ship with- and indeed different IEM need different tips! Maybe try the Samsung tips that work for you on the Buds on the Zero? If you cant get there with what you have . my next advice is , rather than trying to find IEM that fit you, find tips that do- likely cheaper.
Try a mixed size pack of one or both of these:
Moondrop Spring tips
Azla sednafit xelastec
Not cheap at all but also once you find your fit/ size you can make most IEM work for you. Good luck- its a minefield!
You have touched on a really important issue. Eartips and Fit.
When we have devices placed closer to our eardrums, than ever before, every little variation makes an audible difference.
1. The shape of the earpiece, and its design - drivers, shell material, etc, etc. and even more so, quality and consistency of manufacture. I have one IEMs that is obviously faulty, and sounded like garbage, Dead on Arrival, ridiculously distorted - worst listening device I've ever put on my head.
2. Nozzle options for IEM's which have replaceable nozzles.
3. The mesh.
4. The Eartips - external diameter, internal bore diameter, length, the material it is made of, every small change delivers a different level of fit, as well as sonics. I would also add, they differ in the occlusion of external sound, i.e how much noise they cut out from the outside.
Then every ear is different even the ears of the same individual, vary from left to right, and also vary over time. Discovered that those who use custom mouldings, do not just do one for a lifetime, but every few years, MUST repeat the process, cos the shape of their ear canal may have changed.!!
So with all these variables, the challenge is how to narrow down all the options for varying the sonics, to the most important one's, otherwise, one will be tied up in a never ending loop of trying out an impossible number of combinations of teh factors affecting sound from an IEM, somewhat like Hi-Fi enthusiasts who are fanatic about all kinds of gear.
To be continued, this was getting a bit long.
Now this is amusing, Made my day. What will people think of next?
I had the same thoughts and had wanted to post a comment on this, but better I respond to yours. You have touched on a really important issue. Eartips and Fit.
3. The mesh.
I forgot to add, the end user also has control over how deep they insert the earpiece. And in addition to the sonics, the spaciousness, soundstage, and stereo width is also affected, by every one of these factors.
Permit me to add one more factor to the mix. The use of crossfeed, or NOT, in the playback system, and what kind of crossfeed is in use, if applied.
Without getting into the weeds, my experience has been :
1. The technology behind the IEM is the most important contributor to the sound., e.g Dynamic Driver vs Planar Magnetic. vs all manner of Hybrids. If one can afford, over time, trying out one good example of say each of these driver configurations, would be a good education.
Single Dynamic Driver, Dual Dynamic Driver, Hybrid e.g Dynamic driver for the bass, with BA(Balanced Armature) for the upper frequencies - and of course there are all manner of hybrids e.g combinations of dynamic, planar, BA and other driver types., so one can learn what kind of sound they prefer. Sadly yes, the discovery process does involve possibly wasting money on kissing a few frogs, to find the prince. All part of the learning.
I have no regrets buying the Zero 2, but prefer the more open presentation of Planar Magnetics. They are better resolving, more accurate., in my opinion. But that's all I have listened to Single Dynamic drivers and a Planar Magnetic.
The IEM technology and product design, generally we have to leave that to the manufacturers. I know people do DIY, but I think that's taking things a bit too far. Not sure how reliable these modifications are, and it need one owning measurement gear to objectively understand the impact of any user made mods.
2. Eartips - I think, this is such a huge area, and where the end user is completely in charge of refining the fundamental sound of the IEM. Only way to do this is have a good playlist, and run through the playlist, with each change of eartip, find the one we enjoy most or meets our perception best. No other way but trial and error, with some general rules.
2.1 Better seal improves bass response.
2.2 Wider bore improves the mids and highs, and reduces the bass somewhat.
2.3 Closer nozzle to the eardrum, narrows the stereo image, in my opinion. Design of the Eartip affects this, but also how far the end user pushes the eartip into the ear canal also has an impact.
2.4 Eartip material, I hear has an impact. Have not tried anything else but silicone tips. Foams I hear tame the high end.
2.5 Balancing all of the above with comfort, typically trying out different sizes of eartips.
2.6 Also stability of the fit, Some eartips fit well, but need constant adjustment to stay in the same place.
3. The playlist, I think is key, having music which is extremely well recorded, can help to separate the good IEMs/eartips from the better ones.
4. EQ. Sometimes the eartip selection, makes EQ unnecessary.
5. Crossfeed. So many variations, and options available today. Sometimes each eartip needs its own crossfeed setting. I find crossfeed when adjusted properly makes the illusion of hearing things in a space, realistic.
Ultimately there has to be some kind of discipline to know when to stop, otherwise the optimisation effort goes on forever.
The other terrible aspect of all the comparison of options, is adjusting the volume to similar levels, cos otherwise we get a wrong impression, of which option is better.
There is one more - Stereo Balance.
6. If there is any variation in our hearing in frequency response or loudness, or if there is a variation in frequency response or loudness, between the left earpiece and the right, or a combination of these variances. Some adjustment of the stereo balance may be needed. to improve the sonics. And if the variation is significant, no amount of balance optimisation will address this issue. We just have to get used to the imbalance somewhat. Such is life. My thinking is that some of this may come from just nature, IEMs in particular have a way of highlighting these differences, and planar magnetics in particular do this even more, in my experience - not a comfortable discovery, to learn that the left and right do NOT exactly hear the same thing!! Wondering how many of us are affected by this.
So many things to tweak.
Great tips, thanks. In your mind, what is the best planar IEM value for money? I have the Truthear Crinacle Zero Red which is my first and only IEM, so far!
This is a bit too obvious. No contest, the ARTTI T10. I think it strikes the wonderful balance between price, great sound quality, and because it's not a highly publicised brand, they don't seem to charge too much for it, like planar products from more well known brands such as Timeless, Hidizs, Moondrop or Letshouer.
1st it sounds great. I have not heard any other planar magnetic, but going through reviews, and comparing prices, the consensus is that one would have to spend a lot more to get anything much better. I think it is very very well made, and the packaging I received with it, eartips, the cable, case, were truly excellent. obviously made by people who care about their product. Paired with the Clarion TRI eartips, the sound is in my opinion, somewhat even clearer than the stock eartips. But the stock eartips has a decent selection of 6 of them., and I was quite happy with them until I tried out the Clarion TRI - my 1st custom eartip.
I hear the KZ PRX is ok., costs less. You'll have to decide for yourself. The main distinction is the size of driver. PRX uses a 13+mm driver, the T10 uses a 14.2mm driver. The cable and packaging of the PRX are standard KZ fare, nothing special.
For the quality of accessories alone, I'd still say spend a bit more and get the T10.
But there is now the ARTTI T10 Pro with a nice looking metal shell, and a modular cable, with interchangeable plugs for Single Ended and Balanced Connectors. I would have no problem with suggesting this, if it was within your budget., so gone are the 3.5mm and 4.4mm options with the regular T10, cos with the T10 Pro, you have more choice by buying only one product.
Some other possibilities are listed below
BrandModel
HidizsMP145
HidizsMP143
TANGZUWu Zetian
DelciKlanar
ShozyP20
NiceHCKF1 Pro
TinHifiP1 Max
TinHifiP1 Plus
TinHifiDudu
KZPRX
KZPR3
SgorLunar
ArttiT10
LetshuoerS08
LetshuoerS15
LetshuoerS12
LetshuoerS12 2024
LetshuoerS12 Pro
7HzTimeless
May I add. I think planar magnetics deserve to also be paired with the right audio chain, i.e a good headphone amp and DAC. Dongle DACs combine both of these functions of headphone amp and DAC.
I started another thread, where I was expressing a concern about the variance in the sound of the T10 when used with unbalanced, rather than balanced.
I am reminded about how HiFi enthusiasts would labour over each component in the chain. Going purely by measurements, one would think that every modern DAC or Headphone amp would sound the same. But I have heard the difference that a better DAC introduces to the sonics. So strong recommendations with using planars :
1. Get the best DAC you can afford, it matters.
2. Pair this with a powerful headphone amp which delivers at least 120 mW @ 32 ohms (more power is better), with low output impedance, ideally below 1 Ohm.
If you can get a DAC dongle that does both of these in one product - super.
3. I would highly suggest getting the ARTTI T10 with the balanced 4.4mm connector cable, and pairing this with a DAC dongle or Headphone amp, which supports this. In my subjective opinion, the T10 shines with more power, in a balanced headphone connection.
Just to throw it out there: I require larger tips and, while the stock large tips are okay for me, my preferred tips for these are the Comply 500 series oval tips. Emphasis on oval. The circular ones are okay, but I saw no advantage over the stock ones. The oval ones, though, fit me really well and maintain a great seal. YMMV, of course, especially with ear tips, but maybe this information will benefit somebody.
@OK1 - Very helpful, thanks. Running a D50III/A50III Balanced In/Out to Hifiman Arya Organic.
Yes
It's what your brain wanted to hear.
I think it's bit presumptuous to dismiss the opinion of others. Somewhat also disrespectful. I hate to call you out on this, but this kind of attitude ruins online participation.
If I decide to share what I truly believe I heard, I should expect that my opinion, should be very well received, without inordinate critic. I did not come here to debate or argue.
Shutting others down, as you have attempted to do to my comments, really degrades the conversation.
Who are you to comment on my opinion of what I heard? Were you in my head when I heard it?
Assuming you know everything about human hearing, is part of the problem. Please some humility would help, neither you nor anyone else is the authority on human hearing, and has the right to tell others that what they heard, is untrue.
The DAC does not change the sound because the DAC's job is to send a clean and pure signal. A DAC that changes the sound is a poorly designed DAC.
The only part of the playback chain that can make changes are headphones and IEMs.
The DAC only has to convert the sound from digital to analog without changing it. The amplifier "only" has to amplify the analog signal. If this does not happen it is because something is wrong.
No one wants to discredit you, but you can't get angry if someone says something to you and many in here ALSO have technical skills in the audio field.
No presumption here, and nothing against you. I truly believe that you hear differences, and this is precisely why i said that it's what your brain want to hear. Unless you are comparing a very very poorly measuring device, no real audible differences exist, but the expectations and biases generated by your brain, even unconsciously, make you hear difference for real, brain is extremely powerful at deceiving us.
As others have already replied (read the discussion linked by @Berwhale earlier), here at ASR we try to keep this in mind as much as possible, so this "but I heard it" thing cannot pass so easily.
I am not angry, only limited, that I do not have the science to explain the difference I hear in DACs.
Lots of things we cannot measure, yet the people who hear differences in these things can openly speak of what they hear, and no one doubts them or asks them to produce any evidence.
E.g. Different driver topologies do not sound the same, but I have not yet seen any measurement that demonstrates why one is better than the other - NOT one measurement. To demonstrate the benefits or otherwise of dynamic drivers vs planar magnetics vs electrostatics vs Balanced Armature vs Ribbons, etc, etc. They may exist. but I have not seen one such measurement that can empirically show which should be superior from the human hearing point of view.
Yet people tout the advantages or otherwise, of one or the other. With absolutely no scientific evidence, and these are discussed here on this forum.
LetshuoerS12 Pro
I bought the S12 Pro a while back. They quickly became my daily drivers. While (imo) they sound quite good without EQ, a few minor tweaks can make them even better (when isn’t that true?). I don’t see them mentioned here much at all, which is why I figured I‘d throw this out there. They’re certainly a step up from the Zero 2s price-wise, but I feel they were well worth the cost. Not dissing the zero2, though. For the price, they are practically unbeatable.
Not here at ASR. On the contrary you'll always find criticism and irony toward reviews or comments trying to describe a SOURCE sound, as a recent example when this review was shared in the Jcally JM20 thread:
https://audiosciencereview.com/forum/index.php?threads/jcally-jm20-headphone-dongle-review.58749/post-2147116
headphones\iems and speakers are a different matter since, as already said above, they are the only part of the playback chain that can make changes in sound (ok, unless you WANT a source to change it via eq\dsp).
But when comes to sources, no, if they measure equally transparent, all the differences you hear are placebo.
