The RED's bass has no impact or definition.Despite graphing similarly Zero 1 and Red are in different leagues as far as bass responce. Bass is one of Reds high points, just ask around.
That's funny. I gabe my Salnotes Zero cause for me there was no bass on that. In contrast Zero red is spot on.The RED's bass has no impact or definition.
Assuming you got good seal on both sets, like I did, my impressions totally match yours. Red bass was just right, 7Hz Zero was just too lean.That's funny. I gabe my Salnotes Zero cause for me there was no bass on that. In contrast Zero red is spot on.
Maybe I had gotten a "defective" unit?
Exactly, too lean! And that peak around 12kHz... ouch.Assuming you got good seal on both sets, like I did, my impressions totally match yours. Red bass was just right, 7Hz Zero was just too lean.
Yes, the tips are very difficult to replace, even with the ones provided. I had to stretch them using a teaspoon handle (what I had to hand). It was still a bit fiddly even then.As for a lot of IEM's, bass response is a lot dependant on how well the tips fit your ears. If I do not insert them properly I have hardly any bass and they also do not passively isolate me. When the 7Hz Salnotes Zero is properly inserted it isolates very well, the bass is really good and IMHO better than the Zero Red.
I was lucky as the red tips are quite a good fit for me. On the negative side, I find the other tips I would like to try too difficult to replace.
The Zero 2 was reviewed on here a few days ago and is available to buy in many territories.Hi all, honestly never in my life used an IEM before, but lately I feel like listening to music at work. I want it to be subtle so when I come across this review I’m all set to start with one, what else to look for but a cheap but excellent performing set as a starter.
While browsing, I realised there’s a Zero:2 preorder available for a little bit more money. I have no idea if it’s any better for sure without a review here which could be a while (although unlikely, it’s not unheard of that a model got messed up in a new successor version).
Should I get this model now, or preorder the new version? Preorder over here means I have to pay full price in advance and no cancellation.
Thanks!
They just arrived.Finally decided to order my backup unit, now with 3.5mm mic cable.
I already have mic cable of the Hola but it's plug is a tad bulky and doesn't fit perfectly into my smartphone case hole, Zero ha straight thin plug so I pulled the trigger.
I'm receiving variations tomorrow and 7zero2 somewhere in the next 2 weeks.Seriously contemplating just selling my Moondrop Variations and getting a set of these. That will leave me with a nice bit of spare cash. I even EQ the upper treble of the Variations on my Qudelix 5K towards what's already present in the stock tuning here.
Aren't Zero:2 in the photo?Good news, I found the exact same tips only in black after taking all measurements with a micrometer and going through some sets I bought in the past. These look and feel the same, probably the same factory makes them. They have a more sturdy sidewall and don't make flappy noises when moving in your ear, and sound exactly the same. It's from an eBay collection I got for $8 here. I got a TRN T2 Pro16 multi kit and a couple of adapters to check for functionality all the amplifiers I get through. Those clown color tips are the only downside, new daily drivers along with the Hifiman He5xx.
I measured the large red stock tips at:
4.9mm exterior nozzle
6.3mm locking ring on the nozzle
5.4mm below the the locking ring
Tip overall:
9mm high
13mm wide
I measure earphones with an ITU T.Rec P57 Type 2 ear simulator (the Gras 43AC).In the oratory measurements there is nothing of that kink.
Yep it's the blue 7hz Zero:2 I was happy with the sound, so went for a cooler look by measuring them off to find the match in a better color. I have a couple of kits coming this weekend that have the built in microphone, going to check sound quality mainly. I bought the original and Zero:2 and the tip assortment looked identical.Aren't Zero:2 in the photo?
I'm fine with the stock yellow big tips, they give perfect fit and comfort the color don't bother me at all, anyway me too have many spare cheap tips from Aliexpress times ago, I rolls them to when an iem stock tips can't fit well, i.e. with old Revonext QT5 and TRN MT1 i had to try several.
TRN T2 Pro modular cable has really nice feel, got it for about 12€ with all the 3 plugs during last black friday from Aliexpress TRN official store, really good deal, togheter with 2 sets of largest TRN T tips, didn't try them toroughly yet but seems to have good stickiness ad nice fit.
