I don't find Beryllium very compelling. Many manufactures offer models with Be as an upgrade, the times I have listened I don't think the Be upgrade sounds better than the non-Be versions. Plenty of bad sounding Be tweeter applications exist, lots of great sounding speakers lack Be. While I haven't measured a speaker with Be tweeters, the datasheets are widely available. Here is the Radian 850PB series CD, BE and Aluminum diaphragms. The Be version has large resonance at 10kHz, 20kHz, etc. The aluminum diaphragm version may have a hint of the same resonance at 20kHz, but the resonance has no peak at 10kHz. Aside from the bad resonances in the audible bad the Be driver has, the responses are otherwise remarkably similar. I wonder what audible advantage the Be driver has, if any.I’m pre-emptively a bit disappointed by the 12“ woofer in what appears to be a new flagship system + what seems like a variation of the relatively cheap (but nevertheless very well performing) D2 driver. Was beryllium not good enough for a flagship? The 476be exists, after all, and is made by JBL. So does/is the 1500al. Should have just made the DD67000 into a real three-way imo
Here are the ScanSpeak Illuminator D3004 Be and textile dome tweeters. The Be has slightly higher efficiency, does have different response in the 3-6 kHz, has resonances and a more uneven response. I have a hard time understanding which is going to be better, both responses are useable, and the resonances are not as bad as the Radian Be Compression Driver above. I would say this Be tweeter has less obvious resonance than most Be models where a comparison to like model with other materials is available. The Be version has significantly narrower dispersion, which will be less ideal in some speakers, may be a good thing in others. Waveguides will change this though, so don't want to make too much of it.
Lots of tweeters have good response above 10kHz. Be often adds resonances not present in non-Be tweeters, right in the region where they allegedly have benefits. Some have these resonances well above our hearing limit, but those tend to be even larger, like this ScanSpeak D2908 Be tweeter:
I think Be is woo woo, a distraction, expensive, hard to work with, makes driver integration more difficult, yet not likely to achieve better sound. Maybe I am just too cheap though.
