- Joined
- Jan 11, 2026
- Messages
- 400
- Likes
- 222
Of course, if you can get better earphones that also come with USB-C, do that.Thanks for the links but that is exactly my point. Why buy something cheap then spend same amount for some "upgrade".
Even then, the Moondrop Chu 2 is only AU$41 and the cable is detachable, so worse case scenario, you waste the AU$4 extra for the chance of getting better earphones
I was actually considering doing something similar (buying earphones just to use the cable), but I couldn't find anything as the actual earphones I want to use them with have a slightly non-standard connector (Sennheiser's modified MMCX).
PEQ absolutely can make games sound much better (good sound is very important for a good gaming experience!). Although if your earphones/headphones already sound great, PEQ is probably not that important (which is what I thought with my old headphones, but discovered with PEQ that they weren't actually that good, my new headphones however are only slightly improved by PEQ).With gaming EQ is not important, so PEQ is not mandatory.
