7.1.4 Home Theatre Set-Up with Denon AVR-X3700H and AcoustiX RC
Cool Runnings
I finally decided to try to optimize my living room HT set-up about 6 months ago. Here's a quick run down of the journey so far. Any ideas or comments on whether I can do this better is appreciated.
Starting point: The HT is set in a living + dining room combined area of about 6m wide x 10m deep x 3.2m high. With asymmetric doorways/connections to other parts of the apartment. The initial set-up was 3.1.2. LR were 30yo Triangle Altea floorstanders, C was a 30yo Triangle Noxa Minor ES, subwoofer was an old Anthony Gallo TR-2 and finally 30yo in-ceiling Triangles for mid-heights. All connected to the 3700h and running through standard Audyssey RC. I was using this set-up for the longest time. Not very happy with it but not knowing how to make it better and also not wanting to just throw money at buying "better" more expensive gear.
On a whim, I added a pair of Triangle BRA1s upfiring front speakers stacked on the floorstanders. I got a kick out of these by boosting the levels by +6db which made the front soundstage sound a bit taller and bigger and some of the Atmos effects more audible. That made me happy for a couple of weeks. But still not quite satisfied with this 3.1.4 setup.
Next I got into the whole RC rabbit hole of learning how to use the Audyssey RC better with the $20 MultEQ app. This was a gamechanger. Everything sounded better. Much better even without changing any hardware. I finally found some proper audio science handholds to move forward on.
Energized I then swapped out the LCR Triangles for Ascend Acoustic Sierra2 V1s (which I had in my bedroom) and a new 2EX V2 Center. I swapped out the Gallo sub for a SVS Micro 3000 R. And added 2 Cambridge Audio Minx Min 10s (bought second hand for cheap) as back surrounds connected via Dynasty Proaudio WSA5RP wireless connects. And ran the Audyssey MultEQ correct on them. Wow. Another big step-up in SQ. Starting rewatching a lot of movies. Esp Dune 1 & 2 and Gravity and Fury Road lol plus many others.
Next I decided to wall mount the Triangle BRA1s to be proper front heights and also purchased the Dynasty Proaudio WSA5TRV2 subwoofer wireless connect so I can relocate my SVS sub to the right behind the MLP and roughly in the center of the entire living room. So now I am at 5.1.4. Then I got into the A1 Evo AcoustiX RC journey (not easy for a non technical person!). I had 1 limited time window where no one was home and just about managed to do 1 proper run of the Acoustix Express using 1 mic position with 6 runs per channel. Another step up in SQ. For sure the bass response sounds much better time aligned with AcoustiX.
For the last step, I bought a pair of Cambridge Audio MSX20 to be wall mounted as proper LR surrounds connected with another set of Dynasty wireless connects. This will make it 7.1.4. Once I set this up I plan to run a full AcoustiX RC with probably 4 mic positions X 4 runs per channel. Fingers crossed I have enough time window to get this done properly.
What really enabled me to break through from the initial 3.1.2 mediocre SQ situation was 1) help and education from AI LLMs and ASR forum of course. 2) Discovering MultEQ app 3) Upgrading to AcoustiX RC. 4) Availability of reasonably priced but good performing wireless connects from Dynasty ProAudio as I can't run speaker cables all over my living room.
Beyond this, I might add another sub in the future but for now in an apartment the Micro 3000 R is already shaking the room and rattling the windows even at moderate levels.
