Does it matter which source is selected as the input for the amp?Hi, yes I've done this—any external line-level source that has a 3-prong AC cable, when connected to the amplifier's line-level inputs or outputs introduces the hum/buzz.
For example, if you only connect input 1 to a source, but then set the amp to input 2 (which has nothing connected) do you still get hum? If you do, what happens if you then short the input to input 2?
Are the inputs balanced or not?
Does the hum vary with the volume control?
Is there anywhere you could beg or borrow an isolation transformer from to try between the mains and the problematic amp?
