5.5" coax project using Sica 5,5 C 1,5 CP drivers
ppataki
Budapest
After building close to 20 projects using full range drivers and subwoofers and then a two-way system I have decided to strike out one more item on my DIY bucket list: building a coax driver-based speaker
I have chosen the Sica 5,5 C 1,5 CP driver for this project based on the manufacturer published measurements and based on this ASR thread here.
Let's see what I will be able to make out of it!
To start with I have an old pair of sealed cabinets that I used to build for this project. After that they were just sitting in the attic so I thought let's re-purpose them for this new one
The Sica coax drivers shall look like this in this cabinet:
X-max limited max power will be around 45W (at 80Hz where the high-pass filter will pass it to the subs) producing 97.4dB (103.4dB for a pair) of SPL at 1 meter
The drivers will hopefully arrive before 6th January but let's see
I will post pictures, stay tuned
Happy Holidays to all of you in the meantime! :)
If you can chamfer those edges even just a bit, that should be quite beneficial. Those coaxes have a nice continuous curvature to the surround/frame that kinda emphasizes the need
The plan later is to put the speakers in sphere cabinets but first I want to test them in this spare box to see/hear how they perform
If they are good enough then they will replace my full range Markaudio MAOP drivers and the Adam T5V mod project too but if not then I will probably get back to the full range spheres with the MAOP drivers (I really do love those)
Other updates:
Forgot to mention that the coax speakers will be driven by a pair of Sabaj A30A full-digital amps, crossover will be done in Jriver (will try various settings to see which one is the best) and also integrated with two subs in the living room
Just a small update
The cabinets are almost ready, the acoustic treatment is finished:
See a knock-knock test here
The only thing missing is a ring to reduce the baffle cutout so the Sica drivers would fit in - hopefully that will be done tomorrow
The drivers are on the way since Monday but apparently they will not arrive until next Monday unfortunately...
Stay tuned!
The cabinets are now ready (MDF ring added to reduce the baffle cutout)
And finally the drivers have arrived!
IMHO they look beautiful
I will put them in the cabinets today and hopefully I can even listen to them in the evening - will post further pictures and measurements too
This is how it looks like when completely assembled; please disregard (the lack of) aesthetics, this cabinet is only for testing purposes
Now let's see the measurements! All from the MLP (~250cm)
I need to say that these drivers are not too linear...
Woofer:
Tweeter:
So the first thing I did is to fix the response with some pre-EQ, the woofers needed 9 filter, the tweeters needed 5 filters
Huge improvement:
Then I went ahead and applied a crossover using Fabfilter Pro-Q 4. I was experimenting with 2000, 3000 and 4000Hz (all linear phase, 24dB/oct. Linkwitz-Riley) but there was no real difference between those:
So I have checked the temporal graphs too and to me the one with the 4000Hz crossover looked the best so I went with that
Of course I have also listened to all three settings but could not hear any real difference....
Here is the step response:
You can clearly see that the coax speaker is 'seen' by the microphone as a one-way speaker (you can't see the time delay between the woofer and the tweeter - since there is none)
I find this really great but more on that later
Group delay:
Then I went ahead and integrated them with the two subs in my living room:
Then applied Dirac:
Group delay:
Wavelet:
Peak energy curve stays well below 10ms thanks to the correct integration of the subs using linear phase crossover + the linear phase shelf corrections
(there is no audible pre-echo)
I must say I am really satisfied with the end results! These drivers are a bang for the buck (70 EUR each from TLHP once back in stock)
Now some subjective evaluation:
(note: I totally cannot prove the below with measurements, hence subjective)
- before this project I did another one about modifying an Adam Audio T5V just to learn fully active mid/high crossover handling and to hear how a good 2-way system sounds compared to my beloved full range drivers. The Adams sounded great, really really detailed and dynamic highs thanks to the ribbon tweeter but the sound stage was not nearly as holographic as with the full range drivers (even with fully time aligned woofer and tweeter on the T5Vs). There was no 'live sound' feeling at all. I was extremely happy when I heard these Sica coax speakers, their sound stage very very closely resembles that of full range drivers! So if you are having a traditional 2-way or 3-way speaker and you want to listen to how the sound stage can become holographic but you refuse to use full range drivers then the coax can be a great alternative.
- apart from the phenomenal sound stage I can comment on the midrange clarity - I really do like how vocals sound
- treble is not as dynamic and detailed as with the ribbon tweeters but in turn they are non-fatiguing and can be enjoyed for long hours (even compared to full range drivers they are less fatiguing)
- you definitely need a subwoofer for these drivers, they are small and me crossing them at 80Hz is already on the borderline
And finally a video (with Dirac and the two subs)
Any questions/comments please don't hesitate!
So, all your measurements are at 250cm in-room? Looks like impulse right window gating was 300-500ms.
Measurements include many room reflections that make impulse, spl and phase go up and down.
Left and right speaker were on same stand, not at listening setup?
Based on on-axis response at 250cm, speakers must sound quite cold!
That Sica seems to be a very good coaxial. However woofer is so small (Sd) that it is actually a midrange, suited for 3-way speakers
Baffle effect sim
Good to see some overall positive results here. I had purchased the 6.5 inch variant and decided to wait too see whether I would expend the effort.
Will be starting with the Sica passive crossover and plan to have Amir measure with it. All the major subassemblies are complete so will be posting a build thread soon.
Woofer:
Tweeter:
I think you may be measuring/correcting the room here in addition to / more than the driver, we don't use anywhere near 9 filters on the midrange driver of this coax, and it looks like this. You need to measure nearfield, not from the MLP if you want to measure and correct the drivers.
Just a small update
Stay tuned!
Hi! I like those braces!
What are they called?
When I develop a loudspeaker, I try to exclude room influences as far as possible. To do this, the DUT must first of all be as far away as possible from reflective surfaces when measuring.
I first measure from a metre away if the speaker is not very large. I also measure it at different angles (I made a kind of rotating tower with an angle scale for this). Based on the impulse response, I identify the first reflection and suppress it with a gate, like this:
(I measure with REW)
However, this means that the measurements lose their significance for the bass range. To supplement the range, I take near-field measurements (as close as possible) of the woofer and any resonator port, adjust the level of both, make a baffle step correction and then add the whole thing to my far-field measurements. I do all the post-processing in VituixCAD.
In the case of woofer without any crossover in a bass reflex enclosure, for example, a measurement created and processed in this way looks like this:
(here only on the listening axis, shown in VituixCAD after post-processing. By the way, you can see the baffle step, which starts at about 200 Hz)
Another example, a horn tweeter at different angles:
(Here in REW without post-processing as descibed above *edit*: I forgot that a windowing like that is also a kind of post-processing. That means, that windowing is possible with ready made measurments. But to achieve usable results, in my opinion the circumstances round about the measurment-place has to be optimized.)
I consider such an approach to be much more effective for the development of loudspeakers than measuring the individual drivers with full room influence as a basis.
TLHP apparently does not want me to have these drivers. Finally had the funds to get some but TLHP canceled my order citing late payment, but they definitely took my money out the day of the order. They won't budge on the matter so now I'm out a good chunk of change and nothing to show for it. The hell is going on with the company? Guess they're going to see a charge back on this order, no idea why they can't just do the right thing.
I was so excited but I guess I'll just buy some KEF or something, like what the hell TLHP.
Finally got everything sorted and got the drivers.
Manufacturer passive xover seems pretty poor. Here's my driver in box with manufacturer crossover. I built it and that lasted about 3 seconds before I turned it off and started to work on my own. Stock xover kind of tore my head off with treble, wayyy to bright.
Here's the result of my own mod. Tried to leave as much of the stock circuit in place in case anyone wanted to try the mod. It does sound considerably better.
Here's the schematic with the EIR of the Mechano23. My data is gated and I didn't really care what was happening below 200hz with this speaker since it won't be playing that region any. I wouldn't really recommend using the driver lower than 200-300hz.
Tweeter level overall is a little difficult to judge on this speaker. The tweeter has A LOT of diffraction issues that the overall sound. I'd really like to hear a KEF driver now, but the top end of this sica is just too a messy for my ears to keep them around.
I cannot edit my post, but after some listening tests and real world reverse null measurements, the first cap on the tweeter circuit needed to be adjusted to 3.3
