Two Orbits and four suitable subwoofers. I would have done that. Actually, I doubt I would have taken Orbits. Oh, sorry.![]()
I think I can guess that according to him he can do better with the budget in a 2.4 setup with a less compromised bed layer stereo pair. that is my assessment tooWhy wouldn't you have taken Orbits?
here is already an answer:Why wouldn't you have taken Orbits?
And when used with subwoofers, the Palmer's lower octave will be practically irrelevant. But you can look at it another way and not regret cutting off the Orbits' questionable lower octave, if the price is acceptable.do better with the budget in a 2.4 setup with a less compromised bed layer stereo pair
Which subs are you using? I'm currently using Orbits in stereo. Do you think 11x Orbits would still need a sub?I have 3 Orbits as my LCR and I still use subwoofers. I may even get 5 (I only have enough room for 5 earl level speakers anyway) and even then, I would use subwoofers.
I also always use EQ with my Orbits.
Currently 2 SVS SB1000s (non pros the previous version).Which subs are you using? I'm currently using Orbits in stereo. Do you think 11x Orbits would still need a sub?
Might I suggest you start with a budget pair of speakers and learn to EQ them?It's possible that 11 pcs might be enough. It is also possible to achieve a result without significant low frequency problems.
With proper signal distribution, but I don't have enough knowledge about that. Dirac ART mentioned above, for example.
A lot depends on the room.
And what SPL is really needed? 100 and 120 dB at, say, 20 Hz are not the same thing.
Just for fun:
11 Orbits no doubt, cause YOLO!Please, help me decide whether I should purchase 5x Orbit 11's and a DynAudio Core Sub or 11 Palmer Orbit 11's.
Thanks, I have a couple of budget speakers. And four really cheap 18" subwoofers. And there's no need to learn how to equalize. And there are reasons not to equalize. Something is in the signature.I suggest you start with
And 22 Orbits will be equivalent to two lives?)) Or one doubled?11 Orbits no doubt, cause YOLO!
I propose this depends on where bass distortion starts in the Orbits which have a lower F3 than the Genelecs.The Orbit's are designed as full-range speakers. It seems a waste to use the Orbits as bass-limited speakers in this setup and direct everything to a subwoofer. Having said this, you are unlikely to get satsifactory bass response using each Orbit full-range in a surround sound style setup and will probably need a subwoofer (or two or four) to get even bass for surround playback. One subwoofer rarely offers even response even at one seating position but you can get lucky in some rooms. Two are much better and four even more so. Bearing in mind approx 30% of our listening enjoyment is due to bass, I would focus on this area as much as the others. For example, I would take a lower overall channel count at the expense of more subwoofers. A 5.2 system would probably be better than a 7.1 system imo.
I had the Orbits for a while and they are great speakers when used full range, but if crossing over I think there are better options for the money. For example, I would take the Genelec 8030c + subwoofer over Orbit + subwoofer due to the (in my opinion) better SQ from the Genelec.
In the UK 11x Orbits would be £7469. 5 Orbits + Dynaudio Sub would be £6294. I think a better system would be 11x 8030c and two SVS Sb2000 which would be £7246. You get the same channel count as 11 Orbits, slightly cheaper and more even bass distribution + potentially higher overall SQ due to Genelec vs Palmer.
My point being that if used as bass-limited speakers with an 80hz + crossover then the bass extension of either is largely irrelevant (as both extend far lower than the typical 80hz xo range). I previously used the 8030c as LCR (before the 8350a) and found they had quite high potential SPL levels when used with 80hz LR4 filters and subwoofers. The dual 8’s from the Orbits will of course be able to still produce higher SPL at 80hz than the Genelec but again, I don’t think this will matter in practice as neither speaker should produce audible distortion above this region.I propose this depends on where bass distortion starts in the Orbits which have a lower F3 than the Genelecs.
That is what I am moving towardsThe best results with ART come from multiple bass sources, that includes full range speakers. A 11.2 setup with full range speakers would be awesome.
