Hello everyone, you might be terrorized (that's the goal) but if you read it i should convince you that it's reasonable.
I was constantly joking about doing 5.1 on apple dongles ever since I realised how easy splitting 6 channels between 3 devices would be. So one day I got convinced that the joke is actually NOT that dumb of an idea.
@Weeb Labs was the one that convinced me. He also recommended me cheap 6 channel amp. I wanted 6 channels for future 7.1 setup.
So what's the setup. I got linux HTPC with
camilladsp running room correction and mixing. Here's plot of pipeline
I use alsa for mixing output into 3 separate devices. For now i'm using 2 dongles and onboard audio because t5v wanted higher signal. About that…
Speaker setup is:
- LR - Adam t5v - had them on my desktop and decided they were wasting playing youtube
- C - Elac Uni-Fi 2.0 UC52
- Surrounds - wharfedale diamond 220
- LFE - Klipsch R-121SW
Cheap amp I mentioned ealier is WONDOM AA-AB34181 TDA7498. That is powered by 36V 16A PSU, gets 3 inputs from two apple dongles. T5V are connected to onboard because they needed more Volts on RCA. Path is basically USB A -> USB C -> apple dongle -> 3.5 TRS to 2xRCA female -> RCA male to male (interconnect) -> amp. or in case of t5v trs -> rca and in case of sub the sub goes directly to rca female.
So here are the gore pics. Enjoy
Split with overcurrent protection and plug with switch because PSU doesn't have any
Here's psu and amp, i'm printing nice stand for amp and psu is sitting in it's foam because why not (oh ye and they're on top of htpc)
Here are the dongles. Pic from before i switched to onboard. Bit of cable mess but what can you do
Dry setup
AMP + printed stand:
Hope you enjoyed xd Might sound cursed, and look cursed, but it sounds awesome and IS CHEAP AS HELL
