montyliam
Hi guys, I’d like to share my outline for a 4-way active full-range loudspeaker and get your feedback (criticisms, concerns, improvements etc). This is my first attempt at a cardioid design, so I’m starting with more affordable drivers to try and learn the process.
Drivers
KEF Q150 coaxial → midrange / high-frequency (MF/HF).
Peerless FSM-0512 → mid-low (100–300 Hz).
Peerless GBS-200F35CP02-04 → side woofers (20–300 Hz, dual opposing).
Cabinet
Dimensions: 220 mm W × 400 mm H × 400 mm D.
Front baffle: KEF coax + FSM-0512, aligned vertically.
Side panels: GBS drivers and placed as close to the front baffle as possible.
Interior: The KEF coax and FSM driver will each be housed in their own circular enclosure using heavy duty postal packaging tubes. The closest distance the GBS drivers can be to the front panel therefore is around 165mm. I am not 100% confident how to calculate the exact internal volume, but I estimate around 15-20L after the internal parts are taken into consideration.
A generous 35mm round over on the front side edges to control diffraction effects.
Crossover Plan
I aim here to achieve cardioid directivity in the 100–300 Hz region. Below ~150–200 Hz is where the cardioid effect will naturally weaken due to cabinet depth.
Amplification
DSP & Measurements
Questions
Drivers
Cabinet
Crossover Plan
- KEF HF ↔ KEF MF: ~2 kHz.
- KEF MF ↔ FSM-0512: ~300 Hz.
- FSM-0512 runs 100–300 Hz.
- Side GBS woofers: 20–300 Hz (to create cardioid in the 100–300 Hz band).
Amplification
- 2 × TPA3250 stereo boards at 100wrms 4ohm per channel
- One for KEF HF + KEF MF.
- One for FSM-0512 (1 channel unused).
- 1 × TPA3255 stereo board at 160wrms 4ohm per channel for side GBS woofers.
DSP & Measurements
- DSP/DAC: Okto DAC8 initially (later possibly a dedicated FIR DSP board).
- Measurement setup: Dayton EMM-6 mic + Steinberg interface.
- Spinorama jig (5° increments) for precise off-axis measurements.
- Initial XO work in VituixCAD; may explore FIR filters if IIR isn’t enough.
Questions
- Drivers – Should the side GBS woofers really run 20–300 Hz, or would a dedicated sub <100 Hz be better to preserve cardioid performance in 100–300 Hz? My worry is that due to high excursion during high SPL listening levels, the cardioid effect will weaken.
- Cabinet volume/tuning – With ~25 L internal volume, is sealed the best starting point for the FSM and GBS, or should I consider vented?
- Amp headroom – Will the TPA3250 modules be enough for the FSM and KEF sections, or should I consider more powerful boards for future scaling?
- DSP approach – For cardioid null tuning, would you recommend starting with simple delay + gain EQ in IIR, or going FIR early?
- Power supply: I am unsure what will be suitable. Is it acceptable to have 1 supply per speaker running all 3 amp boards, or is it better to have 1 per board or 1 per 2 boards etc?
- FIR DSP chip. If I find the Okto insufficient, are there any FIR capable DSP chips which could be integrated into this design?
