Are you talking about this?:Hi,
I’ve read the so called 4 pin XLR connector for hp. Is it the connector where balanced audio signals flow, just like 4.4mm connector?
The first one looks like 4 pin mini XLR to me
Hi,
I recently made a 4 pin XLR to 2.5mm TRRS adapter so I could plug my IEMs into the 'balanced' connector on the front of my Topping EX5...
Project: Balanced 2.5mm to 4 Pin XLR Adapter
The days are getting shorter and the nights are closing in, so it's project time... I want to plug my IEMs into my EX5. I have Moondrop Starfields with a 2.5mm balanced cable from Linsoul - the Starfields are usually connected to my Earstudio ES100. I'd like to use the 4 pole XLR connection...www.audiosciencereview.com
I could make a similar 4 pin XLR to 4.4mm TRRRS if I could find suitable 4.4mm panel mount socket.
I think it's good that there's choice. Only 4pin XLR feels unnecessary to me. The other four have a rightful place in the market imo. One extra sturdy connector (4.4/6.35) and one compact, mainstream (2.5/3.5)I do find it more than a little frustrating that there are now 3 "common" connectors just for balanced headphones/ iem - nevermind the 2 for single ended. Ive got almost as many adapters as bloody headphones.
Unusual connectors at the HP end aren't a good idea as getting replacement cables can be hard. I agree, at the amp end the 4pin xlr is most robust for weighty cables.It seems 4 pin XLR is more robust than 4.4mm connector, just like 6.35mm than 3.5mm. I had personally terrible experience with 3.5mm connector both to the hp and to the amp when the cable is relative thick. The connection gets loose over time so the contact degrades. Maybe the cable connector type in SoundMagic HP1000 is a solid solution even it is not standard.
Are you talking about these?Plugs are available but too expensive.
https://aliexpress.ru/item/10050017...ist.0.360f1cbbqC0L0f&sku_id=12000024169165247
