4 channel dsp choice help
Ciobi69
hello everyone, i need a 4 channel dsp to put between the pre amplifier and the speakers, better if balanced , what product did you use? i need atleast 15 parametric filters. there are plenty of option and i dont know which one to chose, it has to have in and out soo i can use it between
miniDSP Flex Balanced is the obvious choice:
Uses 1/4" TRS Balanced jacks for I/O:
Sounds like a soldi choice i wish it had more parametric filters but it measure amazing
Limited tabs though, do a search about it around here, there's a lot of documentation.
It would be helpful if you set a realistic budget.
There are many great solutions besides MiniDSP, such as the t.racks DSP 4×4 Mini Pro for €159, or dspNexus DSP audio processors, or scalable software solutions such as Acourate.
my budget could be 500 euro max, thanks for the suggestions i will look the products!
The Flex has 10 PEQ filters for each input and 10 additional filters for each output.
All in all you can configure 60 separate PEQ filters.
now we are talking, thats another thing!
