3rd system pleasant surprise
Luvchampagne
Playa del Rey, CA
My 3rd system is in my 2nd office. It is the lowly step child that gets the rejects.
Prior - SMSL AD18 (combo DAC, integrated amp) powering Monitor Audio Silver 4i. Source is Apple Express using Apple Music from main system.
I had the SMSL AD18 lying around and unused so I put it into service here.
Sound was frankly glorified bluetooth speakerish. Nothing great.
Obviously, not very good but it functions. 57db SINAD as well as numerous other audible issues. :):)
I was cleaning out a closet and came across 2 Marantz MA500 mono block amps. Both with blown fuses. I replaced those and put back into use an unused SMSL 9 DAC as my DAC/Pre-amp.
I think I'm conditioned that most equipment other than speakers sound the same. However, this might be an easy one for most ASR members.
A no brainer in terms of bump in quality.
Thoughts?
The things some people just have floating about...
As lucky as you got with the fuses, you may just have used up one of your 9 cat lives. ;) I mean, I also remember a case of a Denon integrated coming in where a blown fuse turned out to be the only thing actually broken, but a lot of the time fuses blow for a good reason. I can only assume that your MA500s were involved in an incident of sorts, like a mains overvoltage event that had the filter capacitors acting like zener diodes and drawing a lot of current, and written off as defective and shelved afterwards.
Either way, that's mighty posh for a tertiary system. At this rate, a pair of better speakers may be following you home before you know it.
Please do not encourage my ocd equipment collecting /hoarding habits.
Currently have 5 sets of speakers lying around.
Was contemplating moving an used M&K S1-C but then I'd have to hook up a sub. Ugh. Then measure with REW and I decided not but not after thinking about it for a few hours.
These Monitor Audio Silver 4i are not bad. Beat up but still decent.
