3e Audio TPA3255 Amplifier Kit 480-1-29A Review
Rate this amplifier (kit):
    Votes: 3 1.2%
    Votes: 7 2.8%
    Votes: 51 20.3%
    Votes: 190 75.7%
1,5Ohm is only the DC resistance. The impedance while listening music is something else.
how i can estimate it? i have driver datasheet which says 2x3ohm Nominal Impedance, 2 x 2.4 ohm DC resistance for dual coil driver and i connected coils in parallel
You can't. If the manufacturer doesn't provide the impedance characteristic - you can only measure it. And bear in mind if there are any crossover/filter components in the finished speaker, it will have to be measured with them in place also.
But as I stated above - 80C for those resistors is not a problem. It is well within their rating.
Thanks to Audiophonics france, Brazales Mecanizados precission CNC company in Madrid , Spain and my friend Javier technician working for gob here in something related with high precission solar energy 24/7 systems, we have done this dual mono, linear power supply free from SMPS high freq dirtiness, Toroidy polish totally silent transformers double transformers 300va single voltaje, finally voltaje was higher than ordered, but its still on range, dual mono 3e PFFB power balanced amp with Naim/Exposure style bananas made in germany 1000v ready and neutrik xlr screw internal conections, all fastons and what we call here "clema" no soldering at all. internal speaker cable from Inakustik made in germany and other are default or normal fire retardtant. It works its silent!! Very clean with ATC acording my best friend Javier. View attachment 351876View attachment 351877
I am interested in the rectifier boards used in the case. Can you share where you bought them? thanks.
Ha!! What a coincidence you ask me this right now! Recently, after more tu than a year fourth project with tpa3255 pffb modules, FINALLY MY FRIEND JAVIER AS LINEAR POWER SUPPLY ENGENIER, BRAZALES MECANIZADOS MADRID AS THE COMPANY WHO MECHANIZED CHASIS, AND ME CHOOSING ALL PARTS AND VOLTAJES, WE FINISHED THIS NICE PARTS MONOBLOCKS MADE WITH @3eaudio 480-1-29A BALANCED WITH INTEGRATED LINEAR POWER SUPPLY (parts was all purchased in @Audiophonics way before was available that other better measuring tpa3255 pffb modules after measured by asr -we would choosen later if available(cant remember brand was also chinese)- or that latest great amp module without neither integrated SMPS from ICEpower neither still available -we would choosen latest brand if available ) :
Well they are the best sounding (disclamer: subjetive statements without measurememnts warming lol!) of the several tpa325x projects, full body bass , ultra clean, extended highs but not harsh -with a passive preamp transformer based resistorless-, massive sound stage, ....idk why....perhahs the skills of Javier wiring linear power supplies so better dynamics and bass, perhaps the fact are monoblocks true so better imagen, perhahs my great lol skill of braiding internal balanced imput signal or the massive gauge internal speaker cable.... But It sounds BETTER (subjetively for me and my system, dont kill me) than Cymax Purifi stereo power with stock linear power supply (perhahs the different internal audio working or the input selector XLR/RCA partially not working) and the Rotel all discrete stereo balanced power amp modified with Burson o class-A discrete op-amps. Success!!! I Will attach also of the audiophonics shopping list:
ReferenceProductUnit priceQuantityAvailabilityTotal price
18568
3E AUDIO 480-1-29A PFFB Mono Balanced Class D Amplifier Module TPA3255 1x480W 2 Ohm
130,08 €
2
In stock
260,16 €
3675
Custom Toroidal Transformer - All Power
1,01 €
278
+ 30 Days
280,78 €
Transformer specifications: Quantité 2 Profile : Standard Total Power : 270.00VA Frequency : 50Hz Primaires: 1 x 0 - 230 V Secondaires: 1 x 0 - 30 V / 9 A (270.00 VA) Support SF01 + Electrostatic Screen Price : 278 euros TTC
1,01 €
278
280,78 €
1413
HIFI 2000 Case ECO EP1153220 320x200x115
48,30 €
2
In stock
96,60 €
10600
NEUTRIK NC3FD-S-1-B Female XLR 3 Pins socket / inlet Gold plated
9,48 €
2
In stock
18,96 €
10215
Power Supply board for Amplifier 4x10000µF 63V
25,11 €
2
+ 30 Days
50,22 €
18512
Sockets for 4mm Banana Plugs Gold-Plated (Pair)
1,51 €
2
In stock
3,02 €
It is easy to fall prey to confirmation bias when one is passionate about a project... I have personally completed several DIY projects based on TPA325x modules from 3Eaudio, Sylph, Dr. Mordor, and others... I demonstrated via APX555 testing that the power supply had a negligible impact on the module's measurements.
Unfortunately, effusive praise regarding perceived sound quality holds no weight on ASR.
18568
130,08 €
2
In stock
260,16 €
3675
1,01 €
278
+ 30 Days
280,78 €
1,01 €
278
280,78 €
1413
48,30 €
2
In stock
96,60 €
10600
9,48 €
2
In stock
18,96 €
10215
25,11 €
2
+ 30 Days
50,22 €
18512
1,51 €
2
In stock
3,02 €
I am with you. I have both Meanwell LOP600-36 and the LPS I assembled. I like the sound from LPS. It is more full body and has relatively more dimensionality. Here is my dual mono version of 480-1-29a. LOP600's performance is very close with clean, fast sounding.
It’s not a question of being for or against someone... We are on a forum where measurements take precedence over subjective impressions. If your 3E Audio module shows identical measurements with an SMPS versus a linear PSU, then what you're perceiving is automatically confirmation bias...
But if you can prove to the ASR community that your linear PSU actually affects the measurements, then I’d be happy to take your word for it.
By the way, tell us how you measure a dimensional sound?
Let s be factual now.... Here my APX555 measurements of the 3E Audio PFFB with a $80 PSU with and without Extra caps board VS a $ 400 Laboratory PSU
This looks cool and all, but I will never understand why one would build that. This thing below will sound just the same at the fraction of the size and cost:
My objective was to squeeze out the last ounce of the amp board, within my ability. Cost was a consideration but not much. what I meant to say was different ps sound different and I preferred the sound from LPS. High end manufacturers uses LPS in their class D products, such as Atma-Sphere and Jeff Rowland which I got the idea from.
The Power Supply Rejection Ratio (PSRR) of the TPA325X is excellent, and people keep telling you that investing in a very high-end power supply is hardly worth it...
What you are once again interpreting as "different sound" is merely a confirmation bias leading you into cognitive dissonance.
You mention Atma-Sphere, but have you read the specs for those $5,400 Class D GaN-FET monoblocks?
I quote : Total Harmonic Distortion (THD): Less than 0.1% at full powerIntermodulation (IM) Distortion: Typically under 0.04% at full power
I sincerely think—without meaning to offend you—that you haven't understood the nature of this forum....
It's just a placebo effect, the same effect that causes people to prefer the sound from more pricey silver cables and such. If you conduct a proper blind test (there are threads on ASR about how to conduct a proper one if you are interested), you will realize you can't tell the difference between your linear PS and a cheap switching one.
Wow looks great and must sound great also! Yes definitelly there is also subjetively faster and more powerful in LPS than in SMPS regarding sound you cant measure but its there, btw! there is a tiny SMPS just for the power indicator led.... welll.... it blinks very fast like 50hz almost unperceptible but if you stare close its noticeable, rhats the "quality of DC pureness of SMPS" LOL
many people has that feeling hehehe perhaps there is something... Armir once measured LPS vs SMPS nd found more "high frequency dirtyness" on SMPS...
LOOK?
So if the question is:
“Did the LPS products in this test produce lower measured noise than the SWITCHING supply?”
Yes.
You won Dani , SMPS for you and LPS for us ok? I think is not needed to be agressive with no one jusT for report subjetive feelings. BTW i purchased all components in your country @Audiophonics and sounds great
I'm never angry (except when I lose at table tennis lol)
No one is disputing that it sounds great, of course it does when 3e Audios boards are so good! It's just that we don't see the point in adding all that extra bling when there wont be any audible difference (unless you're doing something wrong that is).
Hi Dani,
I've been following many of your posts regarding the TPA325x amps and power supplies, and I know you have a wealth of experience in this area.
I currently own a Topping PA5 and a Mini 300. Having tried three of the original bundled power supplies, I've noticed distinct differences in sound quality among them. This leads me to suspect that these stock power supplies might not be fully capturing or maximizing the performance of these amplifiers.
I remember you mentioned before that unregulated power supplies can offer better low-frequency dynamics. I'm currently wondering if I should reach out to Yongzhuxing to customize a power supply specifically for my TPA3251. What are your thoughts on this?
Thanks!
Hi Dani,
Thanks!
Many thanks)
From a purely theoretical and scientific standpoint, the numerous ASR measurements have demonstrated what I highlighted in the earlier discussion... My perception regarding an unregulated PSU is likely biased... If I were to repeat the experiment, I would probably opt for this PSU (seems great and @fair price)
Many thanks)
Thank you! Based on what you said, it seems I don't need to bother anymore.
Out of curiosity, what made you give up tweaking? Was it because you got into measurements around the "Bamboo V2" project, so you discarded all subjectivism?
