You should think about a finished amplifier based on this board to reach out to wider audience, such a product deserves that.
Wait a bit ) On the way but I can't mention the name of the site which will soon offer it.
92 watts per channel (stereo) into 8 ohms for $90 USD is not what I would call high. Yes, these types of amps will come down in price, but this is a bargain at the current price.This is a very good performance amp, but the price is high for the system used. I understand that 3e is a small builder that can't get parts cheap as Hypex can so he need to charge extra. I don't blame 3e for that, but it shows that relative cheap chipamps with standard amp IC's can be build cheap and good on industrial scale also for probally half the price this one is selling for. That is what we need more...
I don't know where you find 90$ as price, the finished amp in Europe costs about 350€ and the amp board alone (without psu, case and connectors) about 190€. But for 90€ for a finished amp would be a bargain, that is true.92 watts per channel (stereo) into 8 ohms for $90 USD is not what I would call high. Yes, these types of amps will come down in price, but this is a bargain at the current price.
wasn't expect such good performance
That is Alieexpress, so without warranty, possiblity of a fake clone and with import taxes added. I rather buy from a reputed dealer that has warranty and where the price is all included.The US price is $89 for the Stéréo Module ) check here : US market
US does not have same VAT like us in the EU
From Amir's review: "I believe the module name is: 260-2-29A or EAUMT-0260-2-A. Cost seems to be US $90 for the amplifier module."I don't know where you find 90$ as price, the finished amp in Europe costs about 350€ and the amp board alone (without psu, case and connectors) about 190€. But for 90€ for a finished amp would be a bargain, that is true.
That is from 3E Audio's official AliExpress store (their only storefront).That is Alieexpress, so without warranty, possiblity of a fake clone and with import taxes added. I rather buy from a reputed dealer that has warranty and where the price is all included.
People really need PA5 alternative hereWait a bit ) On the way but I can't mention the name of the site which will soon offer it.![]()
My loadbox has a bug that won't work when the negative speaker terminal is above ground so I usually don't run that test on this class of amplification. When I test the mono, I maybe able to do it there.
What are the specs for the inputs? It looks like the sockets accept XLR and 1/4" phone plugs. But what input voltage gets you to max power?Manufacturer Specifications for the Amp Core:
- < 85uV Output Noise (AES17,A-weighted)
- 260W @ 1% THD+N, 1kHz, 4Ω
- 315W @ 10% THD+N, 1kHz, 4Ω
- 111dBA dynamic range
- THD+N < 0.01%, 0.3W – 200W, 4Ω
- 90% Efficient Class-D Operation (4 Ω)
- Fully differential layout design for lowest noise and distortion
- Very Compact size(105mm*90mm*38.5mm – L*W*H)
- Additional power ON/OFF reset circuit for Pop noise suppression
- BTL configuration only for best audio performance
- AUX Power Supply Output(12V/0.2A) for DSP Pre Amplifier
- Single supply voltage range 24V~51V(UVP:24V)
Amir's sweeps have output Watts on the horizontal. Can the AP display also input Volts on a second horizontal scale on these graphs?
It's another board, this exact one is 125 euro on aliexpressI don't know where you find 90$ as price
"JBL Paragon" what we deserved
If that is from the US webshop of 3e, you still need to pay import taxes that add to the price and still got no EU waranty service. But if that does not matter for you, go ahead...It's another board, this exact one is 125 euro on aliexpress
Not sure about taxes but if you can get it for less than [french DIY site] asks why not? It's the same exact board. Chinese. Noname.
But at the same time you can get ICE Power 2x215W for 160 euro https://www.audiophonics.fr/en/ampl...stereo-amplifier-module-2x215w-4-p-17317.html so the choice doesn't seem that obvious. Add PSU, case and some minor stuff including wiring and 160 magically turns into 300-400.
