3e audio TPA3255 260-2-29A Amplifier Review
Rate this amplifier (kit):
    Votes: 2 0.7%
    Votes: 5 1.7%
    Votes: 60 20.6%
    Votes: 224 77.0%
I read your post. Just today.I don't live in Germany. I live in Ukraine. We have different understandings of the amplifier's price. We have different incomes. And there are few opportunities to buy components or parts. Fixing the popping noise (which 3E acknowledged , And he promised to eliminate it in the new batch of boards!) and the information that it will be fixed in the new version of the board has nothing to do with the budget and cost of the board. The defect must be fixed. I'm not the only one on the forum who's heard this popping noise in my speaker. And customers are looking for a way to fix it themselves. I'm forced to buy relays from China. I've wasted my time. For a company to develop a product, they need to point out not only the praise, but also the product's shortcomings. This will benefit the manufacturer, the seller, and the customers. Pointing out a defect or flaw to the manufacturer is not the same as the complaints of some people.
I purchased two 260-2 and two 480-1 boards from Aliexpress recently. Both boards have no on-off popping sound. Completely quiet. Just FYI.
I also bought two 260-2 stereo boards—one in 2025 and the second in 2026. The first board produces a popping sound in the speakers when the power is cut (Amir’s review confirmed this power-off pop). The second board has no such popping sound; it is perfect for me. I had to seek advice on this forum and correspond with 3E to figure out how to eliminate that annoying pop. I sent 3E video and audio recordings confirming the issue. I read many customer reviews; some 3E buyers experienced the popping sound, while others didn't. Why does this happen? Perhaps quality control for the finished boards needs to be tightened? To fix the popping sound, I had to order a relay from China. It meant a long wait and extra cost. In normal times, that wouldn't be a burden, but right now in Ukraine, it has become difficult and expensive—prices have soared while our incomes have dropped. You wrote a post for my information, and I am replying to it. (By the way, 3E acknowledged the defect and provided financial compensation. I am grateful to the company; thank you to them for the help and the compensation. That is why I bought another board from 3E in 2026. It is perfect—no popping or noise.) I assume that 3E has done some additional work to eliminate the popping sound. If that is the case, it is good news for all buyers.
please reach out to our team via email, then will share with you advice.
Thank you for your offer. How can I get your email address? Please send it to me via private message or post it here in the forum thread—whichever works best for you. I am interested in your advice. Thanks again.
According to AE shop being cleared out, to no longer be produced.
Bare board shows at $139 free USA shipping but before possible tariff.
Can anyone link to a good case?
ALSONZONE TPA3255 High-End Amplifier with PFFB Feedback Design Ultra-Low Distortion Stereo HiFi Amp 2.0 Channel 600W Audio Power
The Eco series from Hifi 2000 work well
Galaxy series are higher grade
After > a year without availability, the 3E 260-2-29A is for sale on Amazon again in the USA. I just ordered one for $99. I hope this is not being phased out of production. It is arguably the best TPA3255 board available to DIY builders. Cost is much higher than popular ZK-600x, SAMP-100 and SAMP-200 boards but I believe the 3E Audio board is much more likely to be legit and not a counterfeit. The flat wire inductors alone, justify a higher cost.
Prices for good quality cases in the US are high enough to make one think about just buying the ALSOZONE 6 channel amp which uses 3 of these boards and an internal SMPS in a decent case. Decent cases on Aliexpress are in $250-300 range when you factor in tariffs and shipping and you still have to figure out a heat sink solution.
I am going down a different path and using a case from an old B&K AV6000 6 channel home theater amplifier that had bad capacitors. This particular case has 2 excellent finned aluminum heatsinks on left and right sides with vents above and below that enable passive cooling (no fan needed). Each heatsink is 10" long x 4 5/8" tall with 1" long fins. Two 260-2-29A boards will fit on each heatsink so very possible to build an 8 channel amp. I am using an ICEpower 1200AS2 amplifier board on one of the heatsinks and one or two of the 3E Audio boards on the other heatsink. Only reason I might not use two 3E boards is I already have several SAMP-200 boards that measured well on my test bench.
Power supply will be a MeanWell 600 watt model with Power Factor Correction (PFC) for the TPA3255 boards. I considered reusing the huge toroidal transformer in the B&K power supply to make a high power linear supply but the MeanWell weighs much less, runs cooler, and is more than sufficient for two 3E boards. If I was not using the ICEpower board in this case, I probably would have reused the B&K power supply parts to make a linear supply for 6 channels of TPA3255.
Long story short, careful shopping on Ebay can yield excellent case designs with old amplifiers that need repair. The B&K amps are not that common but I see multi-channel Russound amplifiers in non-working condition fairly frequently. I scored one of those for $100 shipped and will use it for another build. The internal heatsinks are not as nice as the B&K ones but still good for the 3E Audio boards. If you find a broken B&K 5 or 6 channel amp for less than $150, buy it. The heat sinks alone are worth it.
You could consider this PSU BTW :
Looks like a great alternative but the power supply in the link does not work with USA 110 volt AC. Minimum AC input is 160 volts. Otherwise a great alternative. Much higher output power than comparable cost MeanWell.
You re right... Not for US market unfortunately
Here are pictures of the ICEpower 1200AS2 mounted on one of the heatsinks from B&K AV6000 amplifier I re-purposed for this DIY build. This is one of two heatsinks. The other one will easily fit 2 of the 3E Audio boards. Large heatsinks like this in the USA are expensive. I paid less for the broken amplifier. Hope this gives some inspiration to others to look for cheap amplifiers in need of repair instead of spending $$$ on new amplifier cases.
Are you mounting the assembly with the sink above the board so the heat migrates faster?
Yes. Large heatsink like that eliminates need for forced air cooling. there are vents in the case above and below heatsinks.
Excellent! Can you share any links showing more examples, HowTo details?
