At least for the PA5 (II?) I believe it uses a resistor network for attenuation, so... yeah, imbalance wouldn't really be a thing.
Why release an amplifier with such a bad regulator? What is the input sensitivity for the TRS input? If I apply 4Vrms to the input, will there be overload? Is it possible to disable the auto sleep function?Volume ByPass is available
Here are details: LINK to ManualWhy release an amplifier with such a bad regulator? What is the input sensitivity for the TRS input? If I apply 4Vrms to the input, will there be overload? Is it possible to disable the auto sleep function?
Thanks for manual. I see a potential problem, the amplifier is never turned off completely, this means that when there is a power surge it will turn on automatically, then go to sleep again, in the sleep state, as I understand it, it consumes 6W?Here are details: LINK to Manual
Auto disable - no instructions given, so I would say might not be possible easily
Bad Regulator - is it really bad? @3eaudio ?
Yes, I should have been more clear: I don't doubt that (I don'teven know). What I doubt is that the quality of the pot is a fail.At least for the PA5 (II?) I believe it uses a resistor network for attenuation, so... yeah, imbalance wouldn't really be a thing.
It all depends on the specific instance or the batch of spare parts, I don’t know where @Inertiaman saw the annotation about the imbalance of 3-5 dB. Buyers on Aliexpress can open a dispute for a refund for a defective product, at least Aiyima sending buers a new board with a calibrated volume control to get rid of the imbalance. Otherwise, there will be a bad review or AliExpress technical support will award compensation for a defective product. However, this problem is only for those who use a powerful DAC and like to listen to music at night like me and do not want to reduce the output signal from the DAC so as not to lose signal quality and dynamic range.What I doubt is that the quality of the pot is a fail.![]()
Manual says 0.5 watts but my smart plug didn’t detect any.in the sleep state, as I understand it, it consumes 6W?
The informationhas been posted to this thread and it is right on the 3e Audio Website:It all depends on the specific instance or the batch of spare parts, I don’t know where @Inertiaman saw the annotation about the imbalance of 3-5 dB. Buyers on Aliexpress can open a dispute for a refund for a defective product, at least Aiyima sending buers a new board with a calibrated volume control to get rid of the imbalance.
www.3e-audio.com
Note that the 3-5 dB are the absolute worst case in the 7 o'clock position. Everything louder will be way better than that.However, this problem is only for those who use a powerful DAC and like to listen to music at night like me and do not want to reduce the output signal from the DAC so as not to lose signal quality and dynamic range.
Have you tested this in practice? I have and here is the result.32 bit processing of 24 bit audionl data (let alone 16 bit audio) leaves tons of headroom before any signal quality gets lost even in theory.
I don't know your exact DAC and I don't know how exactly you took these measurements, but one thing I know: These two graphs do not represent how a properly implemented 32 bit precision digital volume influences a 16 bit audio signal.![]()
If we use a 16Bit 1kHz signal, then with a frequency of 0dB we get 95dB at the amplifier input.
If we use a 16Bit 1kHz signal, then with a frequency of -30dB we get SNR 66dB at the amplifier input.
Yest is not 32Bit DAС. This test loop E-MU1616M (24bit DAC/ADC, best SNR 115dB, best THD 0,0005%), out TRS -> in TRS (set input level -5dB), from REW 0dB=2Vrms, -30dB=66,4mV.These two graphs do not represent how a properly implemented 32 bit precision digital volume influences a 16 bit audio signal.
one of our reviewer mention this to us and we don't want hid it but also share this to customer,but most of the user case won't hit that point as most likely it only remain at 7-8 clock at a around -40dB gain,if some people really want to listen at very low volume then this case won't fix in our product yet, i am so sorry that this not meet your requirement and thanks for your suggestion which bring us chance for keep improvement.Thanks for manual. I see a potential problem, the amplifier is never turned off completely, this means that when there is a power surge it will turn on automatically, then go to sleep again, in the sleep state, as I understand it, it consumes 6W?
TRS same input as XLR, auto sleep can be disable by modification but that is not suggest.Why release an amplifier with such a bad regulator? What is the input sensitivity for the TRS input? If I apply 4Vrms to the input, will there be overload? Is it possible to disable the auto sleep function?
So for low volume listening A5 would be a better choice I guess to avoid the stand by mode when listeningl'un de nos examinateurs nous l'a mentionné et nous ne voulons pas le cacher mais également le partager avec le client, mais la plupart des cas d'utilisation n'atteindront pas ce point car il ne restera probablement qu'à 7-8 heures avec un gain d'environ -40 dB, si certaines personnes veulent vraiment écouter à très faible volume, ce cas ne se résoudra pas encore dans notre produit, je suis vraiment désolé que cela ne réponde pas à vos exigences et merci pour votre suggestion qui nous donne une chance de continuer à nous améliorer.
concernant la consommation d'énergie en veille, elle est inférieure à 0,5 W, j'espère que cela vous aidera.
I do not know what you actually use in your measurement.16Bit 1kHz signal, then with a frequency of -30dB we get SNR 65.4dB
With measured noise in the range -113dBFS to -115dBFS it seems the first two graphs/measurements show noise mainly from ADC. The SNR of the DAC is probably better than the measurements show.This test loop E-MU1616M (24bit DAC/ADC, best SNR 115dB, ..
Appreciate here for Ed taking his time review and making video share to other people......
Ok. My ADC is not good enough to emulate the amplifier input, because the amplifier's noise level is >120 dB vs. my ADC ~114 dB. But if someone has a 32-bit ADC, like the E1DA Cosmos grade 0, with a noise level of 130 dB, they can repeat this experiment with more certainty.With measured noise in the range -113dBFS to -115dBFS it seems the first two graphs/measurements show noise mainly from ADC.
Thank you. At the moment, it is difficult for me to imagine how the sleep mode will work. I use the computer for office needs, sometimes I leave for 10-15 minutes, during this time someone can write to me via messenger and I should hear a short signal lasting up to 1 second so that I can answer the message, will the amplifier be able to wake up from such a signal and will I hear the signal?TRS same input as XLR, auto sleep can be disable by modification but that is not suggest.
There are people that use a low level low frequency signal to keep amps with audio sense on whenever needed. If you search this forum, you can find it.Thank you. At the moment, it is difficult for me to imagine how the sleep mode will work. I use the computer for office needs, sometimes I leave for 10-15 minutes, during this time someone can write to me via messenger and I should hear a short signal lasting up to 1 second so that I can answer the message, will the amplifier be able to wake up from such a signal and will I hear the signal?
