3e Audio / Alsozone Multi-Channel Amp - Owner's Thread
Those isolation boxes usually have fairly high distortion and at least some low frequency roll-off. Avoiding that usually requires stepping up to Jensen transformers, typically Radial Engineering devices at pretty high cost. I have no idea how the ART T8 measures, but I have liked ART products in the past. If you are planning to upgrade to a balanced prepro, it might make sense to use the T8 as a stopgap.
The testing I saw of it seemed to indicate it was pretty good and did not have those problems. As you say, the long-term plan is to use XLR directly into the amp and hopefully not have problems to begin with. But buying 11 channels of Jensen Isomax off the secondary market sounds kind of expensive.
Internet says the PAM258 has 6 db less gain at XLR in. High and low switch still applies.
It might be worth exploring how it behaves from the lowest gain of 17 db up to the highest of the amp.
You said you've tried RCA to XLR. But was it some generic cable or one for which you know it was wired according to Hypex spec?
As for the RCA cables, you don't happen to have directional signs on the cable hull? I guess you'd know, just checking.
I found an Alsozone Pam 158 on FB Marketplace and I bought a 7.1 set of HTS3001SEs
Current plan is to run my LS50 Metas off a Buckeye 2ch for 2.1 and then run the sats for 7.1 off the Alsozone
However, I'm realizing I have enough speakers and amps to run 5.1.4 (if the LS50s do L/R duty)
Maybe I can pick up an AT500/600 at some point to replace the Flex HT
btw, these little Kef HTS3001SE speakers are absolutely incredible in a small office - they really punch above their size.
So for the satellites?
What about center? My space is large and I want higher output for that than the LS50 L/R
Pricey? I would think 3e A7 Mono would be plenty?
nvm you have the budget not to worry
I'm in a 10x10ft office - the HTC3001SE center is supposed to be excellent but no idea how it would be in a larger room.
I'm not familiar with the A7 but I just wanted a solid amp for the metas. After hearing these little KEFs - I am not even sure I'd miss the LS50s.
Yes the eggs are specifically targeted at lower SPL needs.
Small space like that LS50s are way overkill, as is the amp for those speakers in any room!
Alsozone is plenty, SQ not yet known but you're only going to use half their output, likely fine.
But overkill is not "bad", it's just money
But what is the alternative way to power something like this?
A hot running avr or a bunch of cheap 2ch class d amps with power bricks everywhere?
For 8 channels without 4 external bricks I can't think of anything better than a PAMxx8.
Sure a stack of NCx252 amps would be nice too. But easily 2.5x the cost.
Agreed - I looked far and wide. There was an OSD Nero 7ch class ab available locally for a good price - tempting but the weight and potential heat ruled it out.
There is always a constraint. For me, I was concerned that the 3001SEs would not be great for music and that even if they were, the placement for surround sound is not ideal for stereo so I decided to go hybrid and keep both a competent 2.1 and a 7.1 configuration.
I ordered a Schitt SYS to switch the LR rca channels from the Alsozone to the Buckeye when I want to run 2.1 and switch back to the other amp when I want the wall mounted speakers doing LR duty.
I don't know if this will be distinct enough to maintain long term - I suspect not.
I ran PC surround sound from about 2013 to 2020 and then decided to go for a higher quality 2.1 system. I've been wanting to go back for some time.
I'll try various configs and see what makes sense and where the hidden limitations and problems really are.
Personally I plan to keep the main L/R and subs active "within" the mch system.
I use Schiit SYN for upmixing, and its "modes" allow for a quick switch from center + surround back to Stereo, with three in between
The tone / PEQ / bass management relative levels can be tweaked independently as needed also
It's a bit of a headscratcher when first looking at it, but this thing can automate the Hifi/HT switcheroo. There is also a simpler version with RCA only.
Not applicable for all scenarios of course. Does a good job when there is an AVR and a separate music path.
I don't know what "pilot-controlled" means. Is that their way of saying "manually switched"?
I got the Sys because it was the best looking RCA switch I could find and I wanted all the plugs on the same side.
Scratched my head too!
Summary write up
Summary write up
I think this is to use 2 sources to a single amp.
I'm actually using 1 source to 2 amps.
This is the layout for the maximalist config
Hello. I encountered a problem that after connecting an HTPC, Wiim Ultra and PAM258, I hear background noise through the speakers when the amplifier is turned on, but nothing is playing yet. As I understood from another forum, this is a ground loop. Before that, I had a 3E Audio A7 amplifier and there was no such problem with it. The solution that helped was to disconnect the ground wire going from the power outlet ground to the amplifier. I checked with a tester that the ground is connected to the amplifier body, which is why I got a ground loop. In the 3E Audio A7 amplifier, the power supply unit is external, and the amplifier is not grounded, so there was no problem with it.
Huh, this tracks with my experience - I was getting noise on my amp where there should have been zero chance of having a ground loop. Grounding the AVR didn't fix it. Inserting an ART T8 isolation transformer between the AVR and the amplifier did resolve the problem. Were you using RCA or XLR? You convinced me to open up my spare 25X chassis, and this is what I saw:
I'm not sure it's safe to run this amp without a ground, but 3E can chime in. It does sound like a design issue, and would very neatly explain why I was getting ground loops with no obvious source.
In this case I used an RCA cable. Some time ago I had Denon stereo and home theater amplifiers, and their chassis were never grounded. Here is an example:
How is the HTPC connected? Into the WiiM - how?
HTPC --> hdmi --> TV --> hdmi arc --> Wiim Ultra
Alright. You are coming with a grounded connection into the WiiM. And then go with ground over to the grounded amp.
I experienced the same at one point into a different grounded amp. The problem wasn't the RCA over to the amp but the prior source, which I changed to optical and cut that electric link.
Slim chance, but maybe optical is an option with your TV.
As you have seen the problem doesn't exist when the amp is not grounded. I saw the same with the A7.
Removing the ground from the PAM is not recommended. The device is designed for an electrical class. Wait for 3e to comment before doing such a thing. It might not be safe.
