Someone asked me about the overall experience with my Denon X3800H on DM, and I'll reproduce an edited version here.
I am running a pair of PAM258s and an X3800H. Speakers are PSB Image T65s/C60 with matching surrounds and tops (7.2.4). It works - sound quality is pretty great even at reference - but it's not problem-free.
Basically, the pre-outs on the X3800H seem slightly noisier than I'd prefer (this includes my subwoofers) when nothing is playing. I didn't notice this when I was just running a pair of Atmos tops off a cheap amp, but the lack of gain staging abilities on the amp past "low or high" mean that the PAM258 picks it all up. This is presumably solvable with an analog gain stage, and using RCA to XLR will ameliorate it (lower gain stages), but if you are sensitive to line noise, tread carefully. Note that I'm running in full pre-amp mode on the X3800H, so it's unclear
why this noise is there. It is a lot less noticeable on the surrounds than the fronts. It is definitely not a ground loop (everything is same circuit), and hum eliminators don't do anything. RCA cables are high quality and shielded, and the RCA to XLR ones had the same issues, so it's really gotta be the AVR somehow.
Just to reiterate: this isn't
loud or
ground hum annoying. It's just obvious the amps are on. Once you start playing some media, it's basically inaudible. It was just noticeable because my Denon's internal amps didn't have this noise.
To be clear, with no inputs attached, the amps are dead silent... impressively so. I've been considering trying an external DAC just to verify that the Denon is the true source of the issue, but spending that money isn't appealing right now.
Regarding the amps themselves, my only quibble is that I've had two of the three I bought come with some sort of problem. The first one was used (sold on Amazon by Alsozone as such - fine) and had a dead channel; the second one had a broken RCA input. You need to really carefully assess the amps as soon as you take them out of the box. Alsozone claimed that I must have broken that RCA input and made me pay shipping for the new amp module (which, to their credit, wasn't crazy high, so whatever). I didn't break it, but I guess I should have looked a little harder when I took it out of the box to find the problem faster. Learn from my experience, and test thoroughly on a bench after unboxing.
I'd think about ordering off Amazon so you can process a return if the noise issue bothers you. I'm planning on moving over to a proper pre-pro with balanced outs in the future, which will presumably resolve some of this.
Generally speaking, I do like the amps and think they're an excellent value. Just the reality of using them is complicated.
