No offense taken. I occasionally like to do some low-level tinkering, and given that 3e Audio -- at least at some point -- had the kits/parts for people to build the amp themselves (it is still listed under the products dropdown on their site, but the buy it now buttons take you to a 404 error page on AliExpress), I don't see the issue with inquiring about a little customization/personalization. I don't think of it as being any different than swapping out the op amps.
I also asked because I've had the binding posts on these types of amps fall apart on me before (hence my comment about them being my biggest complaint). In that specific case, it would be easier for all parties involved if it was something the end user could replace themselves in 15 minutes rather than send the whole thing back, and wait for a new unit to arrive.
If that's being nitpick-y, I do apologize. It's just how my brain works. If they're as decent as
@harkpabst says they are (and I have zero reason to doubt that), then I likely won't feel a need to replace them.
This photo does seem to indicate that it might not be too difficult?
It all depends on whether the wires are soldered directly to the post or to a metal tab that is sandwiched between the nut and that square piece of brass(?). If it happens to be the former, I'm definitely not going to screw around with that. I'm also assuming that these are not "full-sized" binding posts (i.e. the same size as ones you'd find on an AVR or full-sized power amp)?
