3e audio A7/A7 Mono Amplifier Review
Rate this amplifier:
    Votes: 4 1.3%
    Votes: 9 2.9%
    Votes: 79 25.2%
    Votes: 221 70.6%
3E aesthetics is like the definition of nothing, exactly something I'd pass over buying on Aliexpress, and offer in no colours :p
It is and that made me think it would be easily improved. At least it's simplistic and the brand and model names are ok. As mentioned above, Alsozone-not so much.
It doesn't have to be full on Schiit style sci fi identity but you need some kind of aesthetic game or the mass market will just not buy into it. Fosi and the others got it, eventually.
Still not perfect and they're still referred to as 'fun fi' by many despite their performance and measurements being anything but.
How do you even come up with a name like that? While having a calzone at Al's?
images
You should see the names for amazon chinese stuff they come up with. :)
I had a Boyuurange 300b valve amp for a while. No real complaints other than the name and questionable design choices. Boyuurange?!?
I'm divided on looks, love the 70s Japanese chrome look but that's a bonus not a reason to purchase.
10/10 times if there is a silver/anodized aluminum version of a device I want to buy, I will get that over the black finish.
If I remember correctly the last piece of silver Hi-fi gear that I had to buy (because the black version wasn't available in Germany at that time) was a Sony ST-JX500L tuner (not my own picture):
That was back when I was 16 or so and I'm very happy this happened such a long, long time ago. ;)
If I remember correctly the last piece of silver Hi-fi gear that I had to buy ;)
I remember back in the last century silver was more popular than black. In the 80s and 70s silver brushed fronts was the standard iirc.
Things changed a lot but a nicely done silver appliance is still an eye-pleaser. Matching is more of a problem today. Black is easy, it won't stand out that much.
Beauty is in the eye of the beholder. I always find it amusing when people talk about the aesthetics of hi-fi equipment in absolute terms, as though their personal taste were some kind of universal truth. Especially when, in the same breath, they hold up some hideous amplifier from the 1970s as the gold standard of “beautiful design.”
Emotiva DRA-1 is on Sale for $499
Im using a SMSL D200 in Preamp Mode driving a Pair of ELAC DBR6.2!
PLENTY of Juice at -20 dB (0.5V) at 8 feet
No Need for Sub!
No Need for Sub!
Some topic drift is OK, but please let's get back on track or let the thread sit a while?
Starting a new one is easy and Free!
Hmm. Not sure I ever fully agreed with that phrase. Everyone has different taste but the principles of good design always apply.
If there is a photo of decent 70s hifi next to any class D amp that looks better I haven't seen it. Even the high end brands.
Just my experience/opinion of course.
I think the 30kg Kenwood amps of my father had a slight advantage in design. Full size, full front silver alu plate and last but not least 5-15x budget.
Also explains why some expensive amps today can look pretty good. Despite bringing nothing more, or even less, through the speaker than top class D more "functional design" amps.
I recently acquired two A7 monoblocks and was quite happy with them (my first class D amps). That is, until a couple of days ago, when I switched from RCA to XLR input.
With the XLR connection, one of the A7s produces a "pop" through the loudspeaker when powering down. This only happens with one of the two units.
I've tried swapping the power supplies, the XLR cables (left/right), and the speakers, but the pop always stays with the same unit.
If I disconnect the XLR cable from the preamp, the pop disappears. There is no pop at all when using the RCA connection.
I also measured the DC offset at the preamp (Aiyima T20):
- Left channel: fluctuating between -0.2 and +0.2 mV
- Right channel: fluctuating between -0.3 and +0.3 mV
Now, here's something interesting: I use both A7s in "volume bypass" mode, but the position of the volume pot still has an impact on the volume of the pop. With the pot at zero, the pop is significantly quieter than at any other position. Only the zero position makes a difference.
Has anyone else experienced a popping sound when powering down? And does anyone have an idea why this would happen only with the XLR connection?
I have found that powering down the A7 monoblocks after setting your source volume to zero (in my case a Wiim streamer) minimizes any loudspeaker "pop".
This too is with both A7s in "volume bypass" mode.
Both of my monos are run & shut down with the position of the volume pot at 12 o'clock. For what that may be worth in the volume bypass mode.
I'm guessing you have already tried this process?
No, I haven't tried this. I'll give it a try!
But I assume the Wiim is connected with rca? With rca no pop at all on my A7 mono.
I run XLRs from the preamp (Saga 2)
RCA's from dac (Topping E30II) to pre.
Optical from Wiim (Pro) to dac.
Due to available/necessary connections, I'm an equal opportunity connector!
Sorry.
Other than the XLR connection, this is probably unlike your setup.
Sorry.
XLRs from preamp (T20)
RCAs from Wiim Ultra to pre.
So not too different ;)
And you have a slight pop on both monos?
