3e audio A7/A7 Mono Amplifier Review
Rate this amplifier:
    Votes: 4 1.3%
    Votes: 9 2.9%
    Votes: 79 25.2%
    Votes: 222 70.7%
Believe it or not, we don't ever get any audio deals. It's still wildly cheaper for me to buy stuff in America, import it, and pay tariffs. Basically, across the board. We are lucky to get 15-20% off our inflated MSRP.
Thank you. Now I feel much better.
I initially bought one unit since they are 2 ohm stable and was going to use it as a subwoofer amp. Currently using a Crown XLS 1502, but it's overkill.
I use Crown XLS2000 for my subwoofers. I'm confused why you think XLS1502 is overkill. I don't see how replacing with A7 mono does anything except save shelf space.
Perhaps that was about the new multichannel ALSOZONE amps
Which many assume will spec out as good as A7, at least not audibly different
Yes! Thanks. The brand shift from 3e Audio to Alsozone kept it out of my sights for many months now. Just as the 3e Audio name became widely established with good amps. Weird marketing.
Gear volume, saving space and weight are critical for me.
Power consumption even more so.
Wow, I never thought power consumption could be an issue with class d.
My class A Parasound amp rivalled my wood stove for heating up a room.
Ok, everything is relative.
Yes! Thanks. The brand shift from 3e Audio to Alsozone kept it out of my sites for many months now. Just as the 3e Audio name became widely established with good amps. Weird marketing.
yes very much not his strong point
Would be a huge upside potential for private equity if located stateside
I guess we should be grateful
I hope they don't cancel the A7. ;)
But it seems the things with Alsozone are in progress right now.
The idea of amps based on the A5/A7 with internal psu and then several multichannel options is very interesting IMO.
Hello,
I am new to the forum and relatively new to the matters of HiFi audio.
I have acquired a pair of used Nubert NuVero 14 and find myself in need of an amp. The irony is that I do not listen at high volumes (need to keep my tinnitus in check - so why did I get these humongous speakers? I don't have an answer) and especially for long durations of time. My question is: would the E3 Audio A7 stereo provide as good of a listening experience at low levels of volume as a A/B class amp?
Hello,
Wanted to report in on my purchase. Got the E3 Audio A7 stereo a few days ago and would like to say that it works great with my current Nubert NuBox 481 speakers. The NUVero 14 have not arrived yet. I am very pleased with it's capability and fidelity. Thank you all for answering my questions on this matter and for empowering me to make a great purchase.
Hello,
I was thinking about using Stereo A7 amp to drive 4 subwoofers simultaneously. All subs are 4 ohm, I plan to connect them parallelly, so each amp channel will see 2 ohms.
I did some research and see that mono version of this amp uses half the components. Except power input. I plan to use PSU 48V 21A, but I'm a bit worried if amps power input can handle it.
Have anyone tried something like that?
A 48V 10A supply is in fact a bit of overkill, which if you want maximum safe SPL, for longevity, usage hours at a time, best to pull at maximum no more than say 80% of amp capacity - headroom is A Good Thing.
At 21A, more than half of the capacity will never be drawn, could in fact supply 2x units if that is allowed.
A 48V 10A PSU is only enough for two channels ~200w 4ohm, or one channel ~400w 2ohm. A7 has been measured and shows that it can handle one channel ~400w 2ohm no problem. What I'm considering is two ~400w 2ohm channels simultaneously. So, about 800w from single amp. 48V*10A=480w. 48V*21A=1008w.
Look at the picture, i found in this thread somewhere:
Stereo A7 is basically two independent Mono A7. I'm only worried about DC input, can it handle 21A...
But I'm leaning towards second amp, instead of 2ohm way.
The PCB and power input of the stereo A7 are not capable of passing 20A even if you were able to force such a high draw. Which likely TPA3255 protective circuitry would not allow anyway
Sure, with 2x separate Mono units, just make sure to split the output back at the PSU or go to heavier guage wiring.
What PSU, link?
If you are trying for maximum output from Mono A7, might as well go to 51V with an adjustable PSU, will have a much greater effect.
That way you could turn the voltage down for those times - hopefully most of the time - when you don't need full power.
You’ve misunderstood something there.
In terms of actual measured output, the A7 delivers over 400 watts per channel as peak power into 2 ohms, not continuous power.
The actual continuous power is around 120 watts per channel—a figure confirmed by 3E Audio.
But really, what speaker actually requires 120 watts of continuous power and over 400 watts for short bursts? Most users vastly overestimate the power needed and rarely turn the volume knob past the 10, 11, or 12 o'clock position.
To get the maximum performance out of the A7, a Mean Well HRP N3 48V 600W power supply is ideal. It delivers 13A continuously and around 45A briefly (for 5 seconds). That exceeds the A7's capabilities, and the power supply itself is extremely robust and responsive.
By the way, those photos are mine.
If you were planning to drive a subwoofer with it, you’d be better off looking at the ICEpower 500/1000ASP or 700/1200 AS1/AS2 models.
Mean Well HLG-600H-48A or HLG-600H-54A might be better EMI/RFI suppression, also fanless.
Note that all these PSUs have a potentiometer for ±15% voltage adjustment.
So easy to crank up to 51V when needed (Carefully! disconnected ofc)
And back down to 41V for longevity in normal usage.
The HLG series also lets you set a current limit, which may help the amplifier's longevity
relevant
These are LED drivers; you *could* use them for amplifiers, but it’s pretty pointless.
The HLG series is optimized for delivering a constant current and has a slow response time, whereas the HRP N3 series is optimized for handling sudden, high load fluctuations—the kind found in CNC machines, for example.
That makes the HRP N3 units ideal power supplies for audio amplifiers, where we are dealing precisely with rapid load changes.
I’ve never actually had the fans in my HRP power supplies kick in during operation. If they were to actually start up, the music would be so loud that you wouldn't be able to hear the fans, even with your ear just 10 cm away.
The 3e Audio A7 is a fabulous amp. I loved them. However they weren’t a good fit for my system.
My tri-amped speakers are very efficient (tweeters are 106 dB) and so that very little voltage is applied to the HF when listening to music at modest volume — too low for the A7’s autosense to recognize that they should be on. If they’d had a 12V trigger I wouldn’t have had a problem.
Unless you are bi-amping or tri-amping very efficient speakers, I expect you’ll be delighted with the A7.
I noticed when power is toggled (also possible from an external trigger) the 3e amps stay on for a while. But I guess they would turn off on you when the signal level is not high enough.
Curious though, did you try a different model like the A5? Did you maybe try to go to XLR in, bypassing the opamp and using only those 20 db, with rca voltage? That's so much less gain on the amp side, it should require your preamp to send significantly more. Well, not 90 -> 106db more but maybe enough to have the autosensing working reliably.
