metal4ever
- Joined
- Feb 11, 2022
- Messages
- 11
- Likes
- 5
sorry, I meant the RCA plugins at the rear of the units. each one have a red RCA?all of the LED's are red, there is no specific left or right amp
The A7 mono amplifiers I’ve handled so far had a white RCA jack.Hey! If I purchase dual 3e A7 mono amps will the RCA connection indicate RED for right amp and WHITE for the left amp? Or will both amps have the RED . I just figured if you purchase dual, one amp will have a red RCA and the other will have a white RCA.
When I connect my pre amp via rca. Right (red) in the right mono amp and left (white) in the left mono ampThe A7 mono amplifiers I’ve handled so far had a white RCA jack.
But why—and for what purpose—would that matter?
They are mono power amplifiers sold individually; there is no specific "right" or "left" unit (nor a "middle" one for a center channel).
After all, you decide which channel to use it for.
Sorry what mono amp model are you talking about that does that?When I connect my pre amp via rca. Right (red) in the right mono amp and left (white) in the left mono amp
You do realize that you have described your solution, not the problem?When I connect my pre amp via rca. Right (red) in the right mono amp and left (white) in the left mono amp
That is just another different DAC.I ordered a USB-C to RCA cable
This sounds to me like the amp is broken. I could speculate about the reasons, but it's uncertain over the net. With pops/static you should check the RCA cables feeding it. And measure the speaker binding posts for DC voltage. Maybe also take a look at the power jack of the amp, the plug should fit properly and firm in there.Worked great for a few weeks, but all of a sudden, I would start to get popping / slight static, then eventually the sound would stop completely. I would unplug the amp for a bit then it might work again, but eventually lose sound again. And then a few days ago, it just stopped outputting sound altogether.
Thank you for your response. I agree it's a different DAC - was just one more variable to eliminate (even though I did have the Schitt one - I figured for $12 for the cable, I could avoid disassembling stuff on my desk). If it's a no go, I can further rule out the amp.That is just another different DAC.
Have you an alternative amp you can swap in?
@3eaudio may comment, or post a query on the Ali shop contact link.
Did you purchase direct from their shop?
Thanks for your response. I've reseated the RCA cables and power jack (swapped to a different one (from 10a to 5a) to test if that - with no positive effect. I'll try with a different set of RCA cables from my Schitt stack to test that.This sounds to me like the amp is broken. I could speculate about the reasons, but it's uncertain over the net. With pops/static you should check the RCA cables feeding it. And measure the speaker binding posts for DC voltage. Maybe also take a look at the power jack of the amp, the plug should fit properly and firm in there.
I have tried swapping the DAC with a Schitt DAC I have, but still same issue
Not sure. I might not have hooked it up right / been on the right setting. Or it was early Sat. a.m., and I was braindead.Any explanation for this?
Yes, 80dB is easy, even in a large room.Would this amp be enough to drive Arendal 1610 slim speakers? I have a Denon 3800h and no external amps at the moment and thinking of speaker upgrade. My usual listening volume is max 80dB.
Yes, not so worried about wattage but the Arendals have 2,95ohm minimum impedance and I read that Denon 3800H is rated to 3,2ohm minimum. 3e audio seems to handle 2ohm wellDoesn't look like a challenge.
I think it's a good combination and will sound as good as these speakers can possibly produce.I am new to the forum and relatively new to the matters of HiFi audio.
I have acquired a pair of used Nubert NuVero 14 and find myself in need of an amp. The irony is that I do not listen at high volumes (need to keep my tinnitus in check - so why did I get these humongous speakers? I don't have an answer) and especially for long durations of time. My question is: would the E3 Audio A7 stereo provide as good of a listening experience at low levels of volume as a A/B class amp?
