Hello Lester
Thank you for your very specific comments
Don't you find it surprising, however, that companies like TOPPING and SMSL don't use these excellent capacitors in their devices, but rather references that remain available from NICHICON ?
Although I should point out that electrochemical capacitors used in audio connections (connected in series) cannot function properly since there is no potential difference that allows electrolysis to work (at least 2 to 3 V between the terminals are required for ionization).
Only polypropylene (film) capacitors are capable of this, and the only reference with this 10µF value is the MKS2 from WIMA (Germany), rated at 50V.
It is small enough to be installed on this type of PCB, but it is '
rather expensive'
I simply wanted to clarify that my comments are in line with the technical and functional interest of the devices that can be offered for sale, therefore necessarily
efficient and qualitative
