If you had even taken a quick look at the review and measurements for the A7, you would know that this statement regarding the A7 is nonsense.I believe an amplifier's power reserve can't be excessive. Depending on the style of music being listened to, 10 watts may be sufficient for 98% of the listening time, while 100 watts (for example) may be required for the remaining 2%.
If a combination of high-volume listening and a short-term peak in the music occurs, distortion may increase exponentially during that 2% of the listening time.
In my opinion, for Rock and Classical, the maximum available (in financial terms) power reserve is useful.
In fact, I looked into both the measurements and the specifications of the A7 before purchasing the two A7monos.If you had even taken a quick look at the review and measurements for the A7, you would know that this statement regarding the A7 is nonsense.
At the same time, amplifier parameter measurements taken on a test bench provide an idea of its capabilities, but they cannot reflect all possible combinations of factors that may arise during operation with specific speakers and specific musical compositions.Unused headroom in an amplifier—whether it’s 20 watts or 1000 watts—has the exact same effect: absolutely none. The rest is purely in your head; it has neither sonic nor measurable consequences.
This is the classic “factors we can’t measure” BS.same time, amplifier parameter measurements taken on a test bench provide an idea of its capabilities, but they cannot reflect all possible combinations of factors that may arise during operation with specific speakers and specific musical compositions.
A real-life situation may differ slightly from a laboratory one.
I believe we don't possess ABSOLUTE knowledge that takes into account ALL possible factors.
Oh, thank you! Classics are always appreciated. That's what you meant, right?This is the classic “factors we can’t measure” BS.
_I believe we don't possess ABSOLUTE knowledge that takes into account ALL possible factors.
What if the amplifier's excess power is needed not only to amplify the signal, but also to convey an emotional component unknown to modern science???The review on page 1 test distortion per power level. Power at low frequency and sweep per frequency. Power into various impedance loads. Power at various phase angles into capacitive and reactive loads.
The only thing missing here is long term (1 minute, 10 minute, 1 hour) sustained load test. However, I think everyone has to admit that isn’t actually relevant for audio.
If you put two amps behind a screen and you can't identify which amp is which when playing any music material of your choice through speakers of your choice, then does the difference exist?What if the amplifier's excess power is needed not only to amplify the signal, but also to convey an emotional component unknown to modern science???
Oh, yes! These little fairies, undetectable by our senses and instruments, are attracted to a certain curve of an airplane wing. As soon as an engineer shapes the wing, these fairies flock to it, but only if the wing is moving at a certain speed. And we thought it was the lift generated by the air.But what if a plane is flying because it is held by a bunch of tiny invisible fairies in the air? :O
Yes, that's what I said)Are you really trying to tell us, that the current state of our understanding of electrics, audio signaling and processing is at the hypothesis state of early pioneers?
You took my quote with a hypothetical example.If you put two amps behind a screen and you can't identify which amp is which when playing any music material of your choice through speakers of your choice, then does the difference exist?
You continue to stretch the already overstretched idea of your argument further and further. If one amp repeatedly and for multiple listeners causes "fatigue" in a blind test and the other doesn't, then clearly, they do not sound the same, do they? And how do you suppose this fatigue-effect would come to be if not due to existing and therefore measurable differences between these amps? And how do you know the current theories of psychoacoustics don't already predict those measured differences to be audible?You took my quote with a hypothetical example.
I agree that the resolving power of human hearing is the final authority in this matter. If a person hears no difference in a blind test, then most likely there's no practical difference for them when choosing between these two amplifiers.
However, this doesn't prove there's no difference at all. I often hear people mention things like "fatigue." I don't know what they mean. Psychoacoustics, self-hypnosis, or something else?
I just want to say that one cannot a priori claim that by obtaining measurements (which certainly have useful practical value) we gain complete and absolute knowledge.
If a person drinks a glass of regular water and the same glass of water with a radioactive isotope, they most likely won't notice a difference in such a blind test. Especially if they know nothing about gamma radiation. But that doesn't mean there's no difference at all.
(etc)Another example is classical mechanics. Did Newton know it was just a special case?
Don't be ridiculous, of course it isn'tBut what if a plane is flying because it is held by a bunch of tiny invisible fairies in the air? :O
Gotta disagree with the Stooges or Lemmy requiring more power. Where are the frequencies and levels producing that in their records. I would argue synth/electronic/bass heavy/merciless 20-80 Hz content tracks.What if the amplifier's excess power is needed not only to amplify the signal, but also to convey an emotional component unknown to modern science???
I think you need more power when listening to Iggy - The Stooges, Kinchev - AlisA, or Lemmy - Motörhead.
Smile - this forum is about music as much as science.![]()
Not at all.Are you really trying to tell us, that the current state of our understanding of electrics, audio signaling and processing is at the hypothesis state of early pioneers?
share.google
My A7se has plenty of power for good old Lemmy and Rock'n'Roll. It is always loud enough.Gotta disagree with the Stooges or Lemmy requiring more power.
Two points:However, this doesn't prove there's no difference at all. I often hear people mention things like "fatigue." I don't know what they mean. Psychoacoustics, self-hypnosis, or something else?
I believe that challenging public opinion is a factor in the development of individuals and societies.Two points:
- "doesn't prove there is no difference at all." Sure, it is great to challenge the conventional wisdom.
I've been reading Amir M's reviews for quite some time now. I find them very interesting and useful, as are the measurements.But the measurements that we show reflect decades of audio research.
With all due respect, you make many statements that I did not make, and you refute them yourself.If you challenge specific finding in an AES paper or a Bruno Putzeys lecture then it would show that you understand the decades of science of amplifier design. If you propose a testable thesis for why class-D amps should sound different than a similar measuring class AB amp, then I would also respect that. If you just say that the science doesn't prove there is no difference, then there needs to be at least some attempt on your part to assert that there is a difference. If there is a difference that we don't know about yet, who is to say that class-D PFFB amps aren't better? What we can say is that when we hide the amp, suddenly nobody can reliably tell a 2 lbs amp from China from a 50 pound old school class AB behemoth.
Actually, I never wrote this about the A7.- "I often hear people mention" is a straw man. Have you heard these amps? Do you find them fatiguing? Are "people" mentioning it actually users of e3 A7 amplifiers?
I have two A7 mono amplifiers connected to the low frequencies in passive biamping. They perform their function flawlessly.I personally own a 3e A7 amplifier which resides in my living room system and I listen for hours without fatigue.
I completely agree with you! The only limiting factor is the available capacity of the local nuclear power plant. We can't be selfish – other people need electricity tooRegardless of the scientific dispute - the only alternative to amp power is more amp power, isn't it?![]()
