Difficult to tell from that without knowing the vertical scale.I really dont think its fixable with eq, here is with 1/48 smoothing View attachment 494521
You might just need a target curve with more of a bass boost - or a steeper downslope.
Alternatively you say you are using USB into the mini DSP, presumably from a PC. Is it possible you have something set up wrong in the PC causing unbalanced frequency response. If not, then play with a graphic equaliser on the source - see if you can find an equalisation that gives you a more pleasing sound to your ears. If you can then you could build that into the target curve for your room eq. Look at the table (link) of which frequencies impact which perceptual characteristic. You may need to be looking at the Upper midrange upwards (1.2kHz and up). Interestingly in your curve above, there is a bit of a boost in that area compared with the bass frequencies. (overall a lump from around 600Hz up to 2kHz which could be causing harshness)
If you are saying everything was fine with a different amp - which amp?
There is nothing ineherent about class D that can cause what you are experiencing any more than from an equally performant class AB amp. Before you waste time and money swapping them out, you need to find out what is really going on. Or you will end up in the same situation with just a different but more expensive amp.I dont really think thats what it is, I expected an improvement in this department after switching from the kefs. Other people have said this about class D
The to most likely possibilities : you are used to a system with a rolled off frequency response - and now you have somthing ruler flat it sound harsh to you.
Or - you have been told or read over years ("other people have said") that class D is harsh and/or clinical - so that is what you are hearing. Regardless of the sound. And remember.....
Perceptive bias has nothing to do with our conscious expectations. The fact that you consciously expected an improvement does not stop your biases creating what you are now experiencing.
