pickyAudiophile
Thanks. Of course from reading articles and following discussions over all these years I learned that attenuating the volume shall be executed not in the final stage of amplification, if avoidable. However, there's these three things why I still prefer not relying on single stage of control.A better way - turn. your amp down to zero, then your dac up to full. Play a loud track. Increase the amp until the volume is just a little higher than you ever want to listen to.
- pre-loudness-war musical content requires one to set the "absolute ever" maximum volume like ....really high. There's also modern anti-loudness content out there produced by artists in a quiet fashion very, very consciously, e/g oftenly used in genres like noise, soud art, minimalism.
For me it's virtually impossible to have three objectives integrated into one single stage of control: protecting speaker drivers, headphones and ears from excess volume shocks, plus a wide and finely graduated range of volume control for all types of musical content, plus suggested smart SNR considerations... - precaution for the case of physical connection issues causing blasts, just e/g hairline-crack broken off from PCB ground connector latches inside of RCA-XLR terminals
- precaution for issues resulting from computing (coding), e/g firmware bugs, electronic volume control position sensing malfunction
Still, if someone could describe briefly whether the pots 3e integrates into their finished amps (A7, A5) are of a stepped, firm, loose, floppy(?) type. ...That would be appreciated.
