It depends of the definition of "equivalent".Wow, I did not think those two were equivalent?
Amir did not even test both units separately, because the A7 Mono is really the same PCB as the A7 (stereo), but only the components for one channel are fitted. The A7 Mono accepts a slightly higher supply voltage, so it can crank out just a bit more power, since the case has to cool one channel, only. An A7 (stereo) can be used just the same when only one channel is used (which nobody would do for two channels because you would be paying for parts you don't use). So, from a technical point of view they are "equivalent".
Using a pair of A7 Mono amps with a dedicated 10 A PSU for each one is still different from using a single A7 (stereo) with one single PSU (maybe even 5 A). Again, if this is needed of not is a different question, but not one for a man on a mission.
I'd say "mostly right". Down to 4 or 3.5 ohms there won't be a difference in power output between the WiiM Vibelink Amp and the WiiM Amp Ultra. the BTL config can provide all the current that is needed. Below that the WiiM Amp Ultra will probably have an edge, but not a massive one, since it's maximum output into low loads is finally limited by it's PSU. Generally speaking, PBTL is better than BTL, of course.While I've gotcha, did I get this right(ish)?
