Hey guys, I see many posts of people swapping the right and left channel op amps on this amp, which I guess are the obvious ones to swap, but what about the other single-end to balanced conversion op amp - especially if you are using the single ended input - wouldn't that be worth trying as well? Has anyone here swapped that op amp? Any feedback on why, even if only using the single ended input, it would still be best to leave the conversion op amp alone and only focus on swapping the right and left balanced op amps? I assume if you use the balanced inputs on amp, the conversion op amp gets bypassed, but if you are using the single ended input, then it's in use and in theory can be swapped for 'tuning' just like the others? I just don't ever see anyone talk about the conversion op amp or see pics of it being swapped and am curious ..maybe most simply use the balanced input, so swapping the conversion one doesn't matter? Thanks!
