That is not always true though, I know it is often mentioned on forums that IMD is more offensive than THD but the fact is, if we are talking about around -100 to -105 dB or lower THD, then to say "absence of evidence.." is not true because IMD will not be an issue if THD is so low. It seems that there are lots of forum posters who for whatever reasons, would like to mention IMD could be the culprit even when THD was measured and found to be extremely low, apparently not recognizing the two distortions are to some extent related. Same thing about harmonic profile they often mentioned, but again, tended to ignore the math, that if THD is -60 dB, "profile" may matter, but at -90 dB or lower, the "profile" is not going to matter much, as even if that -90 dB is dominated by the offensive high order harmonics.
As to measuring THD at 1 KHz test frequency, that is not the case in most of ASR's measurements would include the test results below:
Clearly as frequency increases, THD increased significantly, but then we are back to the audibility conversation that gets more complicated, not in the scope of this thread. For those who is really concerned about distortions vs frequency above 5 kHz, I would suggest they just focus more on comparison graphs among amps, and less so on the absolute distortion levels.
