Hi Amir, is the A7 test still in your To-Do list? Cheers.This review is for A5, not A7. I do have an A7 and it has come with a monster power supply. I will test that very soon.
www.audiosciencereview.com
The TPA3251 should not be used with a voltage above 36 V, so a Mono version (or using a regular A5 for one channel only) doesn't make any sense.@3eaudio Reading the A7 / A7 mono review by Amir here
3e audio A7/A7 Mono Amplifier Review
Since there are dedicated power chips for each channel it's likely all chips run in PBTL mode. That may mean that, in Mono, one chip is idle.www.audiosciencereview.com
He says "internally, just using the left channel of stereo version is the same as mono dedicated unit."
Is this the same topology with the A5? If so that would interest me if you could confirm and explain.
Thank you![]()
OK so the TPA3251 has a voltage limit that the TPA3255 does not, otherwise there would be no point in having the A7 monos either...The TPA3251 should not be used with a voltage above 36 V, so a Mono version (or using a regular A5 for one channel only) doesn't make any sense.
You won't get more power from this setup into higher loads because of the voltage limit. You won't get higher power into lower loads because the PBTL configuration is already rock stable down to 2 ohms.
The TPA3255 also has a voltage limit, of course,OK so the TPA3251 has a voltage limit that the TPA3255 does not, otherwise there would be no point in having the A7 monos either...
Is that correct? Interesting thank you ... I think I got it.
I was curious after reading the A7 review here.
Thank you. I remember something about 3251 vs 3255 on this ... but currently I am going slightly gaga for various reasons.The TPA3255 also has a voltage limit, of course,but a noticeably higher one (51 V recommended, 53,5 V max). The higher the voltage, the more difficult it gets to properly cool these rather tiny chips. Remember that power increases with the square of the voltage. For me this is one reason why mono amplifiers based on the 3255 can make sense.
But maybe @3eaudio will step in giving their point of view.
Am sorry to say but the Soyyin label stencil is really ugly and preventing purchase.would like to share coupon to ASR member : ASRDIS15
correct,A5,A7,A7mono share one PCB design@3eaudio Reading the A7 / A7 mono review by Amir here
Thank you![]()
no lable printed in current ship productAm sorry to say but the Soyyin label stencil is really ugly and preventing purchase.
The faceplate on mine has no "SOYYIN." Arrived April 3 and includes the latest updates.Am sorry to say but the Soyyin label stencil is really ugly and preventing purchase.
What is this coupon good for? Where is it used?would like to share coupon to ASR member : ASRDIS15
on the Aliexpress store. and it's not valid anymore. but there's a "summer sale" right now and you can get 20$ off with one of the coupons AE publish on the main page. some sales have 40$ coupons off purchases over 239$What is this coupon good for? Where is it used?
Back in March it was good for a $15 discount on AliExpress.What is this coupon good for? Where is it used?
Ah okayBack in March it was good for a $15 discount on AliExpress.
Thanks for the informationon the Aliexpress store. and it's not valid anymore. but there's a "summer sale" right now and you can get 20$ off with one of the coupons AE publish on the main page. some sales have 40$ coupons off purchases over 239$
509 Bandwidth Limit Exceeded
The server is temporarily unable to service your request due to bandwidth limit has been reached for this site. Please try again later.
You mean 38V/5A, not 48V,right?Trouble in paradise.
I have two 5se amps that were working fine for about 6 weeks. They were used for highly efficient mid/high dome drivers in a 4-way system, so the load was well below their max. Never saw the clipping lights come on.
The auto signal on/off was a bit of a pain but I left it unchanged. It was set to volume control bypass, and the input to RCA.
I was away for a couple days, so the amps were left unplugged.
Now neither amp produces any output. No lights on one, flicking between lights on the other. But no changes in any of the settings fixes the problem.
When the DC power plug from the 48V/5A is pulled from the amps, there's a slight click from the amp, something like a relay switch.
Tried to get to https://www.3e-audio.com/ but the page tells me:
HELP!!!!!
OMG!!!! Unbelievable.You mean 38V/5A, not 48V,right?
It's a common problem with barrel power connectors. My former boss killed a few thin client computers before realising he was using a 19V supply (from another model by the same manufacturer) not the 12V they needed.OMG!!!! Unbelievable.
Just checked & realized I'd been using the 48v/5a power supplies for my A7 Mono amps, which are idle at the moment.
One of the 5se amps is running right now. No issues. I hope the 2nd one is the same...
Thanks for the quick pickup, @Sokel In my defense, the 48v/5a and 38v/5a power supplies look identical.
