Thanks buddy!These are available as circuit boards and complete units, among other places, on AliExpress.
8 SOIC to DIP Adapter on Aliexpress
Scratch that. I decided to make ( 3D Print) a template and use the M3 threaded holes in the plate.Quick question please.
I want to mount the amp onto a heatsink and to do so want to remove the amps plate to allow access, then re mount the PCB onto the plate/ heatsink.
There's 4 screws on the plate plus two in the centre (assume to fix the chips). Do all 6 need to be removed to separate the plate?
I could just try but figured I'd check.
Thanks.
fosiaudio.com
Hi there,
I've got this small enclosure from Aliexpress by sellers mistake (145x155x54) and could't not use it for more than 5 years because it's to small even for a DAC.
I was really surprised when I realised that it is big enough for 3E Audio amplifier with a MW LOP300-48 PSU.
This is an excellent amplifier. No hiss at all.
Still bigger then Mini300 but more powerful))
Just to finish this off. As I think its pretty dead on this thread! Finished build and the resulting audio is very good to me. I have the absolute tiniest amount of hiss from speakers. Which I can only hear from two inchs away. Happy that is due to either very cheap SE to balanced adaptors. Or connecting class 2 receiver/preamp to class 1 power amp for grounding. Or the 30 foot cables buried in the walls!
Will sort it but if cant I'm not not bothered.
the aliexpress listing says they will discontinue these boards after this batch has sold. Last time I looked there was 50 leftNice work too. From what I understand it comes configured for XLR inputs (solderable)...So 3e will discontinue the board altoghether soon?
3E Audio no longer offers these individual boards. Once their remaining stock is sold out, you'll only be able to find used ones. These will likely be highly sought after.What is the equivalent new board if this is discontinued?
Alternatively, Sylph Audio offers similar boards.
XRK Audio offers both DIY boards and pre-assembled boards (the latter are not always available and are significantly more expensive due to smaller production runs).
Everything else is considerably below this level.
This is good news and will please the DIY enthusiasts and 3E Audio fans among us.Since we are still seeing someone interest in it, we are considering extending the availability period, at least keep making it in 2026
It will be available in the coming months on our Amazon store.Link to a current purchase source in USA?
or at least no tariff uncertainty
