From other reference/drawing I found that XLR pin #1 is ground, #2 is POS signal and #3 is NEG signal. Did you have issue with your XLR connections (judging from your pic)? Thank you
Are your panel mounted XLR connectors male or female?This is my wiring...View attachment 414171
Female, see picture...Are your panel mounted XLR connectors male or female?
I use it with mornsun LOF550-20B48, I temporarily replaced my hypex ncore nc502mp with it in my living room and I don't hear any difference, speakers are canton vento 896.2, subwoofer svs pb1000 and dac sabaj a20d 2020Ok, good to know, as that is how Neutriks are wired. How is yours sounding and what power supply?
Can you do that with / without a load connected.I'll message you a link to a video of the noise happening (while I change the frequency of the sine wave).
Something else worth trying - disconnect all but one board from the PSU to eliminate any effects from components on another board.There's no change in the behavior with or without any load connected (real speaker, dummy load, nothing plugged into the speakon jack)
So it is not output related. It seems not to come from the PSU.The amp makes the same noise regardless of what is connected (dummy load, real speaker, or nothing connected at all).
They didn’t miss it at all.If you power more than one TDA3255 from one single power supply, there will be noise resulting from the slightly different switching frequency of the single amps.
Texas Instruments tells you to make one amp the master supplying it's switching frequency to the following slave amps.
Any decend amp module should supply contact to the corresponding pins. Maybe 3eAudio read and understood the data sheet and implemented this maste/ slave option. It is really not that complicated.
If not it is simple a question of how much the amps differ in frequency, some may make audible noise, others not. The power supply also has some influence on the audibility of this problem.
Even if you don't hear these frequency problem, it still may degrade the sound quality. So ask 3eAudio how to make the master/ slave connection with their product.
Here is a link to the TI information: https://www.ti.com/lit/an/slaa787/slaa787.pdf
I don't think it is wise to ignore such information from the manufacturer of a chip amp if you design amp modules.
