I've seen this table somewhere before and at the time thought 'useful but not entirely accurate (was the marketing department the source?)'. I've not checked every entry, but for example, the entry 36V, 10A, 4ohm giving 190watts: 190W rms into 4ohms requires 27.6Vrms (if you believe Ohm's Law), that's 39V peak required (pk = rms x sqrt2), plus the TPA3255 needs another 5.5V for signal headroom (unless you want your lovely low distortion amp to produce 10% THdistortion+N, or more, in order to claim more output power, as suggested in the TI TPA3255, marketing department-influenced, data sheet - "Engineers don't get it, we need much bigger numbers!!").
So the 36V psu actually needs to produce 44.5volts - these type of 36V psu's I call 44.5V psu's!
