3D printed sphere speakers with Sica 5.5" coax drivers
I have performed all the DSP settings (pre-EQ, Dirac, post-EQ)
Here is how it sounds:
Personally, I am amazed! I can just repeat myself:
- speakers totally disappear (probably due to the sphere shape + the flush mounting + the point-source nature of coax drivers)
- very 'live' sound, almost as with full range speakers
- detailed, airy treble
- vocals don't sound thin
- sound stage is extremely wide (esp. compared to my CHN110 & MAOP in similar sphere cabinets)
At least from my perspective I can safely say that (if size permits) I will only print my DIY speakers from now on
Now I will go ahead and start printing the rear speakers using the same Sica drivers but this time using a passive crossover
I will not put these in the spheres but will use them as external crossovers and for that I have printed a nice little case for them:
So I will continue this thread with this next part of this project :)
Stay tuned!
Stay tuned!
Hey there - any progress with the passive version? Intrigued by this driver.
Yes, I just finished that a few days ago
Printing of the two additional spheres:
Mounting the rear right:
This was super easy as there is a shelf where I could put the box of the passive crossover and it is literally not visible that way
Mounting the rear left:
This looks less 'clean' as I had to fix the crossover box next to the sphere on the wall + there are the cables....
If anybody can recommend any better-looking way to make this happen, I am all ears (I was thinking about using white cable sheets which might ameliorate the looks a bit)
Frequency + phase response in the MLP using Psy smoothing:
That huge peak at 120Hz must be attributed to the corner placement of the speakers
The passive crossover has the crossover point at 2800Hz using 18/12 dB/oct. slopes
If we observe that area, there is no dip in the FR and the phase curve is relatively flat too so I think the crossover is well designed but I am happy to stand corrected here
F6 is 40Hz which is enough for me for rear speaker usage
The elevated highs are 'normal', I experienced the same when I was doing the active crossover settings. However I managed to tame that a little bit with volume and crossover settings (you can see that in post #2 earlier)
Based on all the above, I can strongly recommend the passive crossover version too! (I paid 90 EUR for the pair - extremely fair price IMHO)
So, this is just the standard crossover that is in the datasheet? I’m asking because I may do something with the larger sibling and it also features a passive crossover in the datasheet. Would save an active channel ;) Not a bad result regardless!
As to the crossover box: try to cram it into the sphere? Maybe without the PCB?
Looks great! Glad the passive works well, makes things a bit easier. Now if I could just get them to the US...
Yes it is
This is what they have in the manual:
And this is the crossover I used:
From here: https://www.bsacoustic.com/hifi-crossovers/cn-55c15cp-bs-acoustic-crossover-for-sica/
You can get the 6.5" crossover unit from them too
I definitely cannot cram it into the cabinet, it is really small already
I guess it will stay like this :) (it is OK)
Yes it is
Is the pictured crossover one that SICA makes themselves? And yours is made by BSAcoustic?
The picture above is from the Sica manual
Mine is made by BS Acoustic (Slovakia)
(also see post #21 for pictures)
Have you checked in simulations of port position on the sphere will affect anything. Since you can't physically aim it forward (directly), is there a chance of making it curve from a rear facing output to run along the outside forming a second wall that disperses the port back to the front and become part of your lower adaptor piece?
Just a thought to complicate things further.
That is indeed a very creative idea, thank you!
To be very honest, I guess I will not have time to do it, due to my next project
And even before that, I will be moving to another apartment later this year (due to a divorce that has nothing to do with my hobby - just wanted to be clear about that :) :) ) so I will be happy if the above mentioned project could come to life this year itself
You could hide the cross-over boxes somewhere else and run two pairs of speaker wires to the wall? Could even use a cable with 4 wires instead of 2x2 to minimize the visibility.
Speakons are good for that - 4 pole would do for this, but there are 8 pole versions as well.
Yes it is
I have another crossover question for you experts if I may. Do these two passive dedicated crossovers appear to be doing anything other than applying the high+low pass and (presumably) attenuating the tweeter? I assume any response-shaping like baffle-step, etc. would be too specific to a particular enclosure.
Tlhp shipped my sica order after I talked to someone who can make things happen. Not sure what went wrong with the transaction but its all good now.
Ive been considering printing these spheres, to try something new. My favorite speakers are ones with very minimal diffraction and this looks pretty ideal for that. Are the files available by chance? Id like to edit the port out if possible. Granted I could probably model one up quick but I love being lazy.
...Id like to edit the port out if possible. Granted I could probably model one up quick but I love being lazy.
The ports in THIS THREAD are pretty cool and there is now a website where you can put in the inputs in just a few minutes and download a printable stl file.
I used them in a recent build and they tuned the box to the exact frequency that I put in the input field.
