EirikDyrset
- Joined
- Mar 26, 2026
- Messages
- 18
- Likes
- 27
I just assembled these 3d-printed speakers! I used Dayton Audio RS100 as woofer and SB Acoustics SB26STCN-C000-4 as tweeter. The enclosure is 3 liters sealed. The material is ABS, and it is printed with 30% gyroid infill. I made the design myself using SoundForm as simulation tool.
I use Dayton Audio KABD-4100 with DSP as amp.
The speakers sounds very good. Crystal clear og good imaging. Limited bass ofc (measured f3 is 120), so they should be paired with a subwoofer. I am using a 60 liter ported enclosure with Dayton Audio UM12 as subwoofer here.
Let me know if you want 3D-models for printing it yourself! The design is super easy to print, and easy to assembly. Attached you can see some of the models from CAD.
