Of course, this is obvious, only asking for some additional material that maybe I have overlookedI highly recommend using music you enjoy and are familiar with rather than something someone else thinks is good. There is no point testing Fast Car if you dont like Traci Chapmen and mostly listen to Black Sabbath. From artists you like pick 3 tracks. One that is heavy in bass, one that has prominent vocals, and one all rounder. i find any more than that completely confuses the issue and you start to second guess what you’re hearing. Plus, you just don’t have the time. You want to be able to hear the same track (or even better part of track) on different speakers with as little time elapsed as possible.
Again, obvious and a given, but thanks regardlessI think you should use the music that YOU are most familiar with... music that showcases the aspects you describe is right on, but ideally you will use material that you have listened to for years on numerous systems.
There's something to be said for that.Did that years ago, how do you think I am able to afford $30k speakers?
Presumed so, but could not resist.Did that years ago, how do you think I am able to afford $30k speakers?
Every case is different. Occasionally they are sold on eBay, but frequently there is a friend of a friend or someone's assistant who gets them as a gift.Maybe Mr. Widget can say: What happens to the loudspeakers when wealthy people upgrade? Are their old ones traded in ... like an old car?
House of Flying Daggers Soundtrack (Stereo)
The Echo Game
Crazy stress test of intermodulation effects for bass. I don’t know of any other test track that is as easily reproducible and ABX’able.
Since you are investing $30k into speakers…
Step 1: Buy the Blu-Ray and watch the scene in your home theater. In 5.1, you don’t have to worry as much about intermodulation since each speaker is reproducing a single drum. This tells you what the reference is supposed to be. You get great clarity EVEN WITH mid fi home theaters.
If you don’t want to buy the movie, just believe me that each individual drum hit should be clean and clear.
Step 2: Using the CD or lossless streaming sound track, listen to the same thing and high to moderately high volumes.
I *used* to think that the CD was a horrible master until I got the JBL 4319. In most systems, in stereo, it sounds like a jumbled mess compared to the surround version, especially the latter part of the track.
When I introduced the JBL 4319 into my system, it was incredible how close the stereo reproduction came to the surround reproduction. I have confirmed this with the 708P as well at lower volumes. This is the 4319 at 96 dB does really well with bass, particularly with low 3rd order harmonics.
Admittedly, you may not listen to this song all the time but if you are spending 30k, it seems like passing this at 96 dB makes sense.
And even though the JBL 4319 does great against the Genelec and Neumann, the Revel F328Be is better at this low level control of distortion. I haven’t listened to this track on the Revel.
What I like about this track is that a plain “mid tier” home theater with Studio 530/Revel M106 level speakers and a budget subwoofer is clean. It is easy to know what the truth should be.
It takes a silly high end system to reproduce the same clarity in stereo.
Edit: And remember that 96 dB for a bass heavy track is probably closer to 76 dB for the rest of the music. So even though long term 96 dB listening is bad for your hearing, long term 76 dB listening with 96 dB bass peaks is probably less risky (* not actual medical advice just opinion*).
My current setup (8341a + 7360s + room) controls LF below 70Hz well. I thought the W371a is more for controlling LF in the range 50 - 500Hz? My room issues not fixed by multi subs are in the 100-500Hz range. In addition, I'm interested to see how the cardioid nature of the W371a and the low reflection mode will work with Bacch4Mac.So my conclusion is - if you have a well treated room, capable of controlling LF of <60-70 hz, then there is little need for the w371a. For more SPL only, there are likely more cost-effective options that provide similar results.
I agree with the comments about listening to what you know and like, but since you asked:Howdy all
Will be taking an audition trip later next week (finally!) and was curious as to what everyone likes for audition reference recordings? Of course I have my own list, but would be great to see some new recommends from y’all that maybe I have overlooked. Looking for the usual genres … Female voice, male voice, chamber, orchestral/classical, soundtracks, rock, folk, electronic, acoustic rock, etc. And also tracks that are good for checking the usual sonic characteristics … sibilance, neutrality/accuracy, low freq, imaging, soundstage, instrument separation, walking bass line, pipe organ, mid range accuracy, “air” around instruments, dispersion, etc
Single recordings that capture as many of the typical critical characteristics as possible are best … best case one recording that captures everything would be outstanding, but I am not aware of such a recording.
Thanks again all for accompanying me on this journey
Just discovered these … anyone have any direct experience with below offerings from Starke Sound?
starkesound Product Details
Home Theater Subwoofer,Best Subwoofer,12 inch Subwoofer,15 inch Subwoofer,Ported Subwoofer,Affordable subwooferwww.starkesound.com
Almost no measurements or reviews that I can find except the below …
Starke Sound Halo Elite 5.1 Home Theater Speaker System Review - HomeTheaterHifi.com
Looking for a home theater speaker system that makes a statement in both the visual and aural sense? Then the fine folks at Starke Sound have an impressive looking system to tempt both your eyes and ears!hometheaterhifi.com
Agree. I think the expectations for $30,000 speaker is like the expectation you have for a $300,000 luxury car. It should be do some things that are not practical but done well.Great post, @GXAlan , but 96 dB is quite loud, even just for peaks, if in a daily home environment.
What is interesting is that THX spec is 85 dB average with 105 dB peaks, but the content below 80 Hz is allowed to go to 115 dB peaks.
So -20 dB on a calibrated AVR can get you to bass levels of 95 dB which isn’t completely out of the realm of reasonable listening.
Use that.Will be taking an audition trip later next week (finally!) and was curious as to what everyone likes for audition reference recordings? Of course I have my own list
@MarkS “end game music”, indeed. Love that. I can assure you my list of demo tracks includes such a thing, I have a trail of destroyed speakers behind me (some literally) due to my test tracks … if a speaker and amp can survive my tracks and do so with grace and aplomb, they are truly worthyUse that.
Contra Harman, I'm convinced that music that you're not thoroughly familiar with is useless.
You can't properly evaluate endgame speakers without endgame music.
If you don't yet have endgame music ... well, grasshopper, you may be doing this in the wrong order ...
Hmm. I used my own music selections when I visited Harman for the tests and it was at their request.Contra Harman, I'm convinced that music that you're not thoroughly familiar with is useless.
I think you're absolutely right, what's really the point of doing the audition, the dealer can just play whatever sounds good there. A couple tried it, I stayed for 10 minutes, thanked them and walked out.Use that.
