- Joined
- Mar 17, 2022
- Messages
- 190
- Likes
- 19
- Thread Starter
- #21
Yes Baffle and box effect are included, what's missing is room interactionAll of the PE data files are for infinite baffle measurements. Are you simulating the baffle diffraction or just taking the PE data as-is?
You can simulate the baffle and then simulate all of the off-axis angles in VituixCAD, but it won't be nearly as accurate as real measurements.
You can also simulate the low frequency extension of the mid and woofer (and port) and merge that in VituixCAD.
Sorry if you have already done this, but it is not clear from your post.
If you haven't done this, the first link in post #8 HERE might help.
